A WPA passphrase is a user selected password for your wireless network. It must be the same on the router and any connecting devices, and you need to be sure that the format matches (wpa or wpa-2 and psk or tkip) . The exact meaning of all of this alphabet soup is less important than the fact that all of these parameters match.
to get the wpa key, you need to access your dlink by making sure you are hardwired to the router. then open up an internet explorer then type on the address bar the numbers 192.168.1.1 then look for wireless settings. you should see the wpa key there.
Good day, In default you can see the wpa or network security key under the router. It should be on a sticker under the router labeled WPA or Network Key. Usually its beside the model number or serial number of your router as well. Hope this information help you. Have a great day.
If this is for you trying to access wireless internet the WPA key is the wireless security key needed to use the wireless router. Usually you can find the wireless key on a sticker on the router or it is supplied on a card when you first receive the router.
WEP or WPA are the types of wireless security. If your wireless network is secured then there will be a password on the network that is called as wireless network key or passphrase ( WEP or WPA key ). PIN number is different than WEP or WPA. To check the wireless network key ( WEP / WPA) you will need to access the router settings page. On that page , you will find all the settings of the router.
You need to connect your computer hardwired to the router and reconfigure it. On your wireless computer, you need to delete all the preferred networks and add a new wireless profile.
the WPA key, is usually found on the side or the bottom of your wireless router, usually on a pink sticker, with WEP or WPA,
then will have a random numbers and letters, its case sensitive.
other option is login to the router through internet explorer with your routers ip address and under security tab you will find the security key..
