There is a black rectangle in the bottom third of the screen. It goes away if you change channels and if you change volume but then reappears.
The rectangle is approximately the size of the set up window except there is no type in the black rectangle. When I access the menu, then type appears in the black box and turns transparent, but once I exit the menu, the black box re-appears.
Could it be that you have closed caption enabled? Maybe there is just no captions, but you have it enabled.
Located the manual here if you need more:
http://dl.owneriq.net/0/00313ef3-996b-4df4-9792-07c9fa4bbbfc.pdf
Hope this helps.
Check your Closed Captioning settings in the menu. I would bet money you have the "Text" feature enabled. Change it to OFF and you should be all set. I hope this was of some assistance.
