Blomberg washing machine
I have a blomberg washing machine 1501aaa and their is a loud noise coming from the machine when it spins
I have a blomberg washing machine AAA rating with "fuzzy logic". Now it is not working, will not fill with water or spin, but you can see the dial turning and going through the dial settings. Whats wrong. Can anyone help and I have lost the manual.
Carla
Posted on Aug 29, 2009
    New Friend:
Switch off power. Then open the filter cover front bottom left hand side, drop the little flap down and place a shallow container under flap. Unscrew the filter part way until water starts to pour out. repeat process until empty. Then pull out filter housing and check inside. You may need a pair of long nosed pliers or long scissors to hook and material out. Spin the paddle wheel to check the drain pump turns freely then reassemble. Open door and check the drum spins freely and there is no freeplay in the bearings and no grinding noise.
Pull the machine out and undo the two Torx 20 screws at the back each side just under the top cover and slide the cover back a little and lift off. Look for the three springs being in place. If one is off hook in drum first, then lift drum manually and slot back in place on top mount, if the spring hook has opened up, close it a little, using mole grips. Then check the belt turns the drum ok, is the belt present or come off/snapped?
Undo the 12 Philips screws on the back panel and remove panel. Look at the motor mounts to make sure not broken. Look and feel for the nuts and bolts that go through the dampers on each side of the drum, make sure they are tight, if you can turn a nut, then get spanners and tighten up securely. Put back on, have a final check to make sure there are no broken earth wire to drum problems, if so, re-terminate. This one often snaps as the drum can drop. If all ok, then replace the top cover. Now is a good time to take a quick pic with the mobile phone of the model identification label, if not just jot down the model number on paper. Finally, switch the power back on and select short spin. If the drum was loose, ie a spring come off, then the drum rattling around could have damaged the door seal, so it may leak. Door seals are relatively easy to renew. If it doesn't work, now is the time to call in an expert!
Posted on May 10, 2015
  • 16 Answers
If you open the door and spin the drum by hand it should sound perfectly quiet and feel perfectly smooth. If it is not and it sounds "like a jet taking off" as some people describe it - that would probably be your bearings.
If the sound is a loud rattling sound - then something is probably loose ( usually top or bottom weights )
It would help if you could describe the noise as best you can!
Posted on Mar 16, 2008
SOURCE:
Why do i have loud noises coming from my washing machine only whilst it spins
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
Aug 21, 2016 | Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Blomberg Washing Machine WM77110 shows "door" error. Unplugged, and turned on again, but still error sign is on.
Thank you Sandy for your suggestion. It was the right fix for us. My daughter had opened the door 6 minutes before the end of the cycle (which I didn't know) and next day when I wanted to do laundry it showed an error. We were going crazy because we couldn't make it work. I read your comment (to tell you the truth with no hope) but it worked!!! I'm so happy didn't have to call the repair man which would have charged more than $100 to see it. Thank you!
Nov 01, 2014 | Blomberg WM77110 WM77110 Washer 1.95 Cu....
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
How to reset my washing machine blomberg
you cannot reset it anyway its NOT that, you have a door sensor fault most likely or a MCU problem look get a service manual and follow that.
Mar 10, 2012 | Blomberg Washing Machines
Water draining makes loud noises
if water isn't draining properly the cycle will stop thereon check the drain pipe
Oct 12, 2009 | Washing Machines
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Washing Machines Logo
1,029 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
