Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch dishwasher water not draining away from bottom of dishwasher. can you advise
    Novelist:
  • 131 Answers
1. Check for a clog in the air gap:
That's the silver dome on the back of the sink. Not all homes have an air gap for the dishwasher. (Though it is highly recommended!) Lift off the silver cover. Unscrew or unclip the plastic cap on the top. Look inside. Toothpicks are often found there.
2. Check for debris in the sump by:
Remove the lower rack, the lower spray arm, and screens. Use a #15 Torx bit to remove the cover over the drain pump suction. The hole leading to the drain pump is on the left at the bottom. Remove any debris you find.
3. If you find no debris, you almost certainly need a drain pump. After clearing any clogs, if you hear the drain pump humming, but it doesn't turn, replace the pump.
Comment back if you directions for this.
Posted on Mar 12, 2008
Water is not draining from Bosch Dishwasher 10 yrs old
Give this video a try. There are lots of places where gunk can build up and this video shows you how to do it on a Bosch dishwasher.
Dec 04, 2017 | Bosch 24 in. SGS43C12 Classixx...
Hi We have a 1 yr old Bosch dishwasher SGS45C02GB-06. It's stopped working for the second time in a year. It stopped mid-cycle and the water is not draining away or being pumped away; although you can...
Did you install the high-loop for the drain hose? If not, you need to pull out the dishwasher and make sure that the hose is not lying below the pump at the bottom of the dishwasher. This will usually fix this problem.
Jan 05, 2011 | Bosch Dishwashers
My bosch SGS3062GB is not draining the water away - the water is stagnent in the bottom of the dishwasher. I ran the rinse cycle and it left about 2.5inches on water in the bottom of the...
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Dec 13, 2010 | Dishwashers
Won't fill with water
Bosch dishwashers typically have flood sensors in the bottom, below the motor. If there is still water in the pan the machine will not fill with water and only try to run the drain pump. Be sure there is no water in the dishwasher pan
Dec 02, 2017 | Bosch Evolution 800 SHE68M05UC Stainless...
My dishwasher will not drain
You will need a specialist to come and fix that. You might mess up your whole drainage system doing it by yourself.
Jul 05, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Drain pump runs continuously. Nothing else happens!
Water had accumulated in the sump - a plastic tray at the bottom of the dishwasher which catches any leaked water. This operates a float switch which makes the drain pump run all the time. The fix was to tilt the dishwasher backwards to drain away the water. It isn't filling up again, so I'm not sure where the water came from, but I'll keep an eye on it!
May 17, 2009 | Bosch Dishwashers
Bosch dishwasher wont drain
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Feb 22, 2009 | Bosch 24 in. SGI43E05GB Built-in...
Bosch Dishwasher
what is the model #?... there are 2 buttons when pushed together it will drain the water out..try the button to the left next to power scrub... and economy...hold the 2 buttons for 3 sec. you will hear you drain pump running.. if you don't hear any water draining out into your sink, you might have a clog d/w drain line.
May 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
321 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
