Question about Sharp AR-168D Copier
Service mode I just had time to replace my drum. Can you tell me how to get into the service mode so I can reset the drum, developer and maintenance counters? For the service light is still on. So I would like to reset these to see if the light will go off. I appreciate your advice. Thanks Kathy
  • kathy389 Mar 17, 2008
    I have not had time to work on our copier for I have been swamped with paper work at the moment. I will get back to you on this matter.
    Sorry.
  • Asif Workshop
    Asif Workshop May 17, 2017
    How do i clear the error code C413 at Toshiba estudio 2505
    New Friend:
  • 18 Answers
To enter the service mode, press the keys as follows:
[hass] key [interrupt] key [C] key [[interrupt] key
For clearing maintenance counter press 20 then 01. 000 will display then press C.
For Drum counter press 42 then 02.
Posted on Jul 31, 2014
    Problem Solver:
  • 10 Answers
Hello:
All I have access to is the Toshiba Version of your machine but I think maintenance mode is the same.
This is the excerpt from the relative info in the service manual.
Example:
Basically you press # * c * ( to get into maint. mode
Press 20 Start 01 start (then the maintenance counter will clear)
I hope you can figure it out
The drum and dev counts are below
To enter the serviceman test command mode, press the keys as follows:
[#] key [*] key [C] key [*] key
To cancel the test command mode, press the [CA] key.
[10KEY]:(number pad) Entry of MAIN CODE/SUB CODE
Selection of an item
Setup of an adjustment value in case of test commands for adjustment
[/]: Selection of MAIN CODE/SUB CODE
[OK (ENTER)/START]: Settlement
<In case of test commands for print>
[OK (ENTER)]: Settlement (Without print)
[START]: Settlement/Print
[C]: (Interrupting operation check) Returns to the upper hierarchy.
In case of test command of operation check, terminates the operations.
[CA]: Exits from the test command mode.
For a test command of adjustment, the display returns to the initial display (00-00).
20 01 Maintenance counter clear (M-CNT CLR.)
24 06 Developer counter clear (DVLP CLR.)
24 07 Drum counter clear (DRUM CLR.)
Posted on Mar 12, 2008
  • Ann Office Automation
    Ann Office Automation Jul 31, 2014
    At service mode use interrupt in stead of *. Maintenance: 20 01, Drum 42 02.
How clear Maintenance m2 call service this konica 164
M2 means maintenace time you have to replace 1) developer 2) drum 3) cleaning blade 4) drum charge unit and reset the maintenance counter / calibrate the ATDC. After you than that READY TO COPY will appear ;-)
Oct 17, 2014 | Konica Minolta Office Equipment & Supplies
CAUTION MAINTENANCE CALL (M2) CALL SERVICE
Replace the developer and drum/cleaning blade. Also reset the counters after replacing parts then run F8. resetting the counter with out replacing the above items cause image problems. The copier uses the counters to determine voltages on the drum you tell the copier drum is new and it is still old will cause problems.
Sep 18, 2013 | Minolta bizhub 180 Black and White Copier
Sharp printer MX-2301N Code TA
Thanks for choosing FIXYA.
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Have a nice day.
Jan 18, 2012 | Office Equipment & Supplies
I replaced the drum unit to my Minolta DI2510 copier; but the message to replace the drum unit has not gone away. How do i reset the message?
You can not just reset the drum counter. When you reset the counter then the ATDC reference value is also reset. This will throw off the developer to toner ratio and your copies will usually become light or overtoned. The developer is supposed to be replaced at the same time the drum is replaced. The drum count is then reset and the F8 function in the service mode is run to calibrate the new developer. If you do not perform this procedure in the right order and correctly you will end up with at best poor copy quality. I would recommend calling a service person out to change the developer and then reset the counter and do the F8 procedure.
Good Luck and Thank You for using Fixya.
Feb 02, 2011 | Minolta Di2510 All-In-One Laser Printer
On my bizhub 250 copier, there is a message stating " Please change PC Drum" My question is, How do I change PC Drum?
This is a service technician performed function. The PC Drum unit is changed by removing the whole imaging unit and then removing the drum section and changing it out. At the same time the developer needs to be cleaned from the developing unit and replaced with fresh developer. The drum counter is then reset using the service mode and then the new developer must be calibrated using the F8 mode. So in this machine's case, this is just not a pull out the old unit and plug in a new one.
If you find the "right" service guy, he can come in and reset the drum counter and do the f8 without changing either the drum or the developer. This can sometimes get twice the life out of the unit. Copy quality can degrade a bit towards the end of the second cycle.
If you just reset it your looking at around $100. If you do everything that is called for then the cost is more like $350.
WheatlandServices
Jan 20, 2011 | Minolta bizhub 250 Black and White Copier
Price of Konica Minolta imaging unit for Bizhub 162
You do not replace the Imaging Unit as a whole on this model. The Imaging Unit is made of of 2 parts. The Drum Unit and Developer Unit. If your "replace imaging unit" indicator is on then typically what happens is your local Konica Minolta or Independant service shop would come out and replace the Developer (aka Starter) in your developer unit and replace the drum unit part of your imaging unit. This must be done in sequence with resetting the counters in the service mode. If not done properly the counters will not reset or the new developer will fail to calibrate properly so copy quality will be poor or you will end up with a COF32 code. That being said, all I can tell you is that a fair price to perform this scheduled maintenance on the 162 is about $350.00. This will vary depending on local labor rates and how much the dealer marks up their parts. My current cost on the drum unit and developer is about $100 so you can use that as a general guideline in case some dealer tries to rip you off.
WheatlandServices
Nov 20, 2010 | Minolta Konica Imaging Unit for DI350...
Panasonic DP-8020P Machine Maintenance count reached.
yep. as long as the print quality is good and stable, and the toner consumption is good (8K to 10K of pages per bottle) you can just reset the maintennace count at f7-03 on service mode. probably your machine count reached at 120k. :)
Nov 02, 2009 | Panasonic DP-8020E Black and White Copier
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
Enter the maintenance item
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Press the enter key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
1. Press the enter key. A selection item appears.
2. Select On using the up/down cursor keys.
3. Press the enter key.
4. Turning the power switch off and back on.
ADDING TONER is displayed and installation of toner starts.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
Sep 14, 2009 | Kyocera Copystar CS-1820 Black and White...
Our bizhub-250 receives a C2557, need help with service mode
Utility/Counter -> Details -> [STOP][0][0][STOP][0][1]
Go to counter and clear the life of the developer and drums and then run F8 from functions.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 11, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Sharp MX-2300N Maintenance required.code:TA
Dec 23, 2008 | Sharp MX-2300N Color Copier
Sharp AR-168D Copier Logo
687 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
