SUBWOOFER output just purshased a jensen MPX6411 it has only 1 blue rca jack for a subwoofer istead of a red & white. I want to hook up 2 subs 2 6by9 & 2 6.5 how do i hook up my subs to that single (blue) RCA
  • 405 Answers
I have a Yamaha subwoofer yst- sw005. How do I connect this to my mobile or tv. Does it work without an amp or receiver?
It's an amplified subwoofer. You have two inputs. Right and Left. If you plug in speakers into the output jacks, you can get a 1/8 inch to RCA and plug in a mobile device and the subwoofer's amp will power the speakers and sub.
To hook it up to a TV, the TV has to have audio outputs (White and red, usually paired with a yellow RCA jack. labeled Audio/Video out)
Nov 03, 2017 | Yamaha Audio Players & Recorders
Wiring diagram for jp12 subwoofer
your sub woofer has only one input to make it work. plug in your rca cables into the back of the sub woofer and the other end into the audio out or subwoofer out put on the back of your surround system.
also has 2 speaker inputs so you can expand your speaker setup. plug thos in and you can hook up 2 speakers to th output on the back of the sub.
Jan 29, 2011 | Jensen JPS12 Subwoofer
How do i connect a subwoofer to my vsx-9700s
on the back of the pioneer, you have a subwoofer preamp output jack, probably colored black, as opposed to red or white. stretch a rca cord between there and the red and white (or lfe) input of the sub. youll then have to check the amp setup menu and make sure it has the output activated. good luck
Feb 11, 2010 | Audio Players & Recorders
2 RCA's coming from amp into radio's single subwoofer output RCA?
You can either hook up the left channel only or buy a splitter that separates one input into two outputs.
Oct 03, 2009 | Pioneer DEH-P690UB CD Player
My amplifier has one pair of rca inputs. radio only has 1 output
Subwoofer signals should be MONO - not stereo (hence the single Component out on the radio)
Only use one RCA to send signal to your amplifier.
If you use a Y splitter - the signal voltage will be cut in half - deteriorating the quality, and therefore amplifying "dirty" signal.
If you require further help, simply reply to this thread.
Thanks for using FixYa - a FixYa rating is appreciated for answering your Question.
Apr 09, 2009 | Jensen Car Audio & Video
Jensen uv8 and amp hook up
Remote wire from Jensen is blue or blue/white. Use Blu/white if there is one. . RCA's, for subs, use the rear if no subwoofer pre-outs are available. If unit has sub pre-uts, use them as the head ubit (stereo) would have a level that can be raised or lowered thus giving you more control over the input to the sub amp.
Jan 28, 2009 | Jensen VM9510 Car DVD Player
How to connect Jensen subwoofer CS10 to Yamaha Receiver HTR5660
Does the yamaha have a subwoofer line out RCA type jack? Most receivers with 5.1 output will. Just insert a male rca to male rca patch cable from the receiver to the line in on the subwoofer,( not the speaker wire inputs) Plate on the sub may say low level input, and setup the receiver menu option for SUB? yes/ no to yes, this will direct the low frequencies to the subwoofer.
Jan 25, 2009 | Jensen CS10 Speaker
Connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Nov 22, 2008 | Audio Players & Recorders
    Onkyo 805 sub hook up problem
    Talked to tech support at Onkyo and there seems to be two (2) places you can hook your sub up to. I placed mine in the wrong slot. So please double check where you placed the sub connection.
    Jan 05, 2008 | Audio Players & Recorders
    114 people viewed this question
     Grubhead
    Grubhead
