Question about Sony Playstation 3 (PS3) Console
Connect Wireless I have no idea of what I am doing. I bought me a wireless router and a range plus USB adapter, both from linksys, I want to get online with the ps3 and have NO idea how to do it, any help? please?
  • Pisper Mar 12, 2008
    thanks
The PS3 doesny need an adapter, its already wireless. You need to set up ur wireless network as normal, the connect your PS£ through the settings :)
Posted on Mar 12, 2008
How to connect Tivo to WRT160N router wirelessly
you need to go to tivos website and see what "wireless usb adapters" are available for your unit.They range between 40 to 80 dollars each if your tivo is wireless compatible
Nov 06, 2009 | Linksys WRT160N Wireless Router
Blank square on screen after installing a Linksys USB adapter
This is a problem with the wireless adapter to correct this problem you uninstall and download the latest software from linksys site and install that one to your computer...
Sep 26, 2009 | Linksys Rangeplus Wireless Pc Adapter
Netgear wg111 - I am connected to wireless network
i have seen issues with wireless USB adapters. Can you try another USB port on the computer? Also delete the adapter and let it br reinstalled. If this does not help, I would suggest returning it and getting a Linksys adapeter.
Jun 15, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Wireless-g usb adapter fails to connect to router
if your wireless router has security enabled, as a first troubleshooting step you can try disabling the security. then see if the USB adapter can connect. IF it still cannot conenct check for the default channel on the router and on the adapter side.
Jun 03, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Upgraded Acer 2500 Travelmate with a Wireless card
hey there is a external linksys wireless network adapter that works well it plugs in your usb slot
they are by linksys.
Linksys
Range Plus Wireless USB Compact Adapter should get you the correct range for around home and outside in your yard. check ebay for this solution its much cheaper here. thanks Kawuna
Dec 01, 2008 | Acer TravelMate 2500 Notebook
No connection to desktop, but great connection to laptop???
Hi Lindsay,
The very first thing that you need to do is to personalize the wireless settings of your ultra range plus router. Since your laptop is wired directlty to the router and is working properly, you can access the router's GUI to personalize the wireless settings. Open internet explorer on the working computer and type http://192.168.1.1 on the address bar, you will be prompted to enter a username and password, by default there is no username and the password is "admin" if you have setup a password using the setup cd then use that one.
Now your inside the setup page of your wireless router, look for the tab the say's Wireless and below you will find four sub menu namely; Basic Wireless Settings, Wireless Security, Wireless Mac Address and Advance Wireless Settings.
Under Basic wireless settings change the Wireless Network Name(SSID) to something you prefer(this is a must).
For the Radio Band, set to Wide 40Mhz. Wide Channel(9), Standard Channel(11) now click on "Save Settings".
Now got to Wireless Security and for the Mode choose(WPA Personal/PSK Personal) Enter a 8 or more digit password under passphrase and click "Save Settings".
Now your done setting up your wireless router it's now time to connect your desktop wirelessly.
If your using a linksys wireless usb network adapter more or less you have also installed the WLAN Uiltility but personally I use the built in WLAN of XP and Vista.
Using the linksys WLAN Utility for to the Profiles tab and highlight default.
Click Edit and it will provide a list of available network(SSID) that your computer detects.
Select the name(SSID) that you provided the router earlier and click connect.
It will not prompt you to enter the WPA Key also known as passphrase(remember the 8 or more digit password) then click Connect to the Network.
You should now have a valid internet connection wirelessly on your desktop.
Oh and for your 2nd question the answer is No, since you already purchased and installed a wireless usb network adapter for the desktop computer you don't need to purchase a long ethernet cable or move the desktop to where the route is.
Hope this will help you get connected.
Regards
Jul 23, 2008 | Linksys Ultra RangePlus Wireless Routr...
Wireless Network
You can get a Wireless Range Expander to repeat the signal of the router and Linksys also has that the model is WRE54G it will solve you signal problem...
Hope that helps........
Jun 27, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
