Help wiring normal hp compaq eplaced power supply no power
Help wiring hp compaq replaced power supply
    Scholar:
  • 101 Answers
I am assuming this is a desktop and not a laptop. On the power supply you have a number of connectors. A 24 pin connector (like a lego block) or a 20 pin (leg block) with a 4 pin (in the pattern shown on a dice) Look at your motherboard and check whether you have any connectors which match these and plug them in. They only go one way round as they are shaped. You will need to plug in the wide white 4 pin connectors to everything else like your CD, your hard drives. The floppy drive has a separate smaller white connector. If you have a sata drive these are usually black and flat. Basically you need to connect some wires to your motherboard and one power cable to each of your devices, hard drive, CD/DVD, floppy drive. It doesnt matter which one you choose. Just one that will fit. If you have a souped up graphics card there may be a 6 pin connector for that either on the board itself or on the graphics card. The 6 pattern is the same as a 6 on a dice also.
Good luck.
Posted on Mar 12, 2008
Power supply damaged, Can I replace it with any other model power supply?
A standard ATX PS won't fit in your low profile case. The plug types can be different too. Usually there's a schematic with a PS that describes the wire color of each voltage. So you could conceivably shove the pins out of one PS plugs and insert them into the different plug, or solder the wires to the correct pins, and leave the PS outside of the case.
Nov 16, 2013 | HP Compaq dc7600 Small Form Factor PC...
My hp compaq power converter is not supping my laptop with power. ASSIST
your problem is the wire of the adapter from the laptop to adapter it might be loose contact or wire has been cut you need to replace it or have it check to the service center,
Aug 03, 2011 | HP Computers & Internet
MY HP COMPAQ 5000BMT BEEPS REAPETEDLY WHEN POWERED ON.THE INDICATOR SHOWS RED.WHAT IT THE PROBLEM?
Normally when a computer beeps repeatedly it means either you power supply has failed or *********** board, to test this get hold of another power supply that you know is working and use that one to boot your mechine, if you have the same problem then unfortunatly *********** board has failed and will need to be replaced. hope this helps
Sep 26, 2010 | Computers & Internet
Compaq Presario SR1265CL replacement power supply
You can replace power supply the higher wattage the better.
Mar 21, 2010 | HP Compaq Presario SR1265CL-B...
Hp compaq dc 7100 psu 24 pin SLIM LINE
why wont you buy a new power supply or a plug that converts from a 20 pin to a 24 pin
Mar 31, 2009 | HP Compaq dc7100 PC Desktop
POWER SUPPLY 24 pin slim line colour code ,hp compaq dc 7100
normal white wire....?
white with red....?
brown....?
Power Supply Connections
Not every wire that comes off the power supply is used so this might be worrying over nothing. I'd give a quick look at all your components inside- especially the cd or dvd players as well as the CPU fan. If it looks like everything is okay, power it up. When your system runs its POST (power on self test), it'll tell you if something critical is missing. If not, use it as normal. If something really is unplugged, later on you'll find out because it either won't work or a function of it won't work.
Aug 15, 2008 | HP Compaq Motherboard
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
