CD and DVD Burners
Problem for CD and DVD Burners
Generic problem for all CD and DVD Burners
Problem with LITE-ON DVDRW SHW-160P6S ATA...
By Skilled1_99 on Mar 12, 2008
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available.
I check for driver updates and it says i have the correct and most up to date driver but my computer still doesn't recognise it.
Can you help???
Same Problem
Apr 05, 2009
-   Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Can you help???-   gerriedupree
Jan 24, 2009
-   same thing that him-   Guest
Jan 08, 2009
-   I have the same problem (code 39)-   8484
Jan 06, 2009
-   I have the same problem but mine says code 10-   Guest
Solution #1
posted on Mar 24, 2008
Somewhat Helpful)
exon33
Rank: Guru
Rating: 88%, 316 votes
There is a whole bunch of helpful stuff at http://www.tomshardware.com/forum/196090-32-lite-dvdrw-160p6s-burning-problems
Seems that the drive may overheat, and will need replacement if in warranty. Some advice given: get another type drive. Also, check the device manager and make sure it's running in DMA mode and not PIO mode. If you have an nForceX mobo and using the SW IDE driver, reinstall with the normal IDE driver and try again. In device manager, check under IDE ATA/ATAPI controllers. Right-click and select properties on the IDE Channel your DVD recorder is attached to. Transfer mode should be set to "DMA if available". Current transfer mode should be "Ultra DMA Mode 4". If it says Mode 2: Your drive may be experiencing problems which are causing windows to drop its speed. There is a support article with a fix. To surmize:
After the Windows IDE/ATAPI Port driver (Atapi.sys) receives a cumulative total of six time-out or cyclical redundancy check (CRC) errors, the driver reduces the communications speed (the transfer mode) from the highest Direct Memory Access (DMA) mode to lower DMA modes in steps. If the driver continues to receive time-out or CRC errors, the driver eventually reduces the transfer mode to the slowest mode (PIO mode).
If you have dropped from DMA mode 4 to DMA mode 2, and you have a spare ribbon cable, you may want to try swapping it out. Also, if there is another device on the same channel as the DVD drive, try disconnecting it.
Was this helpful?
Yes
No
Solution #2
posted on Dec 14, 2008
Somewhat Helpful)
ricardojar
Rank: Apprentice
Rating: 75%, 2 votes
I don't have one I need one
Was this helpful?
Yes
No
Popular Solutions for CD and DVD Burners
Questions and Unsolved Problems for CD and DVD Burners
Answer
I need an internal cd/dvd burner drive tray where to buy one
Answer
hello sir/madom my name is palamkuttalmathai i did not use any cdearth software but november28... (More)
Answer
The cruise control on my 1998 Chev Z71 just quit working. What should I check first?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burner Experts
Top Computer & Laptop Repairmen
in , OH
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
