I have to unplug my computer to make it come on.before I unplug it the on button light is blinking on and off
    Scholar:
  • 101 Answers
Usually a power light blinking indicates a problem. The blinking is coded to indicate what the problem is. Try consulting the manufacturers website and look up the manual for your model. A dell particularly has coded blinking lights. Without know the make and model it is difficult to judge.
Posted on Mar 12, 2008
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
Hp pavilion slimline power supply
you bringing a marginal part or connection back up a working state. when it cools or voltage drops it goes to the non working state. hp power supplies are not good to begin with. replacing it will fix it till that one also fails
May 23, 2017 | Computers & Internet
My at&t Motorola 3360 has every light blinking but is still working. The Power and DSL are continuously blinking red and the ethernet, internet and activity are all blinking green.
Here's the thing...if the modem is unplugged, and you press the "Reset" button, or any button, nothing will happen because the modem is UNPLUGGED.
When you plug it in again, there is usually a few minutes or so during which time the lights will blink. Eventually, when the DSL connection is established, the blinking should decrease. But, there will always be some blinking going on to indicate that data is being transmitted.
If the "Ethernet" light is blinking, then a computer that is plugged into the router is transmitting/receiving data. If the "Wireless" light is blinking, then a computer that using a wireless connection to the router is transmitting/receiving data.
If a red light blinks, then that usually means the DSL connection has been broken. When that happens, for whatever reason, the modem will automatically begin its initialization routine and will continue to do so until connection has been established. During that time, LEAVE IT ALONE.
If you uplug the device, or if you press ANY button while the device is attempting to correct itself, you can cause permanent damage.
So, you are correct. It's not a problem. I'm sure you've heard the phrase "If it's not broken, then don't fix it." There's a lot of truth to that.
I hope this helps.
Randy
Dec 01, 2012 | Arris 3360 AT&T DSL Modem - -
Computer won't come on. light is blinking in back of hard drive.
Try unplugging from wall socket then press on button (this clears out extra electricity in PC). Plug back in then try to turn on again. If PC is older, try blowing out the dust inside tower especially around the CPU fan.
Aug 04, 2012 | Compaq Computers & Internet
The machine appears to be stuck in a wash cycle. After unplugging the machine & plugging it back into an outlet you have no indicator lights. The only button that has a response when pressed is the...
this machine sounds to have a computer board problem I have a calypso washer also and i had the same problem so I ordered both computer boards and replaced them and everything was working like new , I haven't had any further problems since
Jul 31, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
I have a dell 5100 laptop. This morning i removed a program through add/remove programs. The computer need to be restarted. During the restart I left and came back the power light was blinking so I pressed...
Our expert technicians provide you dell tech support for desktop, computer, laptop, printer, drivers, etc. Call at our number 1 (800) 204-4427 and get 24X7 quality services.
May 19, 2017 | Dell Inspiron 5100 Notebook
There are two blinking green lights that will not go off. The computer screen is dark. when i press the turnoff button, the computer green light on the right hand side of the computer continues to stay...
Unplug the laptop and remove the battery. The discharge the laptop by pushing the power button for 15 seconds while it is unplugged and does not have the battery installed. Then put the battery back on and power it up, and use your laptop as you normally would.
Nov 08, 2010 | Dell Latitude D600 Notebook
Blinking lights
I left if off and unplugged for a few hours. When I plugged it in it started working again. My recommendation if this happens to you is to just unplug it all and let it stand for at least 4 hours and then plug it back in.
Good Luck
Oct 01, 2008 | Sony RDR-VX555
Power light blinking
That is because either you screen is dead(test by connecting a exteral monitor) or you motherboard is dead and I have been seeing many dead motherboards as of late
Sep 19, 2008 | Toshiba Satellite A45-S250 Notebook
Blinking lights
this means your printer wast pad is full this is now oyu reset your printer but make sure you have put new pads in 1st and dont for get to rate plz
  1. Turn off the printer power and unplug the power cord from the wall. Disconnect the computer interface cable at the back of the printer.
  2. After one minute reattach the power plug to the wall, but don’t reattach the computer cable.
  3. Hold down the ROLL and the PAPER ADVANCE buttons simultaneously.
  4. Turn the printer on. after 2 blinks, all the ink lights come on, then release the buttons being held down.
  5. Press and hold the ROLL button for 10 seconds.
  6. Release the ROLL button and the printer will initialize, which resets the Waste Ink Pad Counter.
  7. Once initialization is complete, turn the printer power off.
  8. Reconnect the interface cable.
  9. Turn the printer on and print a document.
Sep 11, 2008 | Epson Stylus 2200 InkJet Photo Printer
Computers & Internet Logo
252 people viewed this question
David Payne
David Payne
