Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
BROTHERINTELLIFAX775 I CANNOT SEND A FAX, IT TELLS ME THE LINE IS BUSY AND I DO NOT HEAR A DIAL TONE ON THE FAX MACHINE.
  • Anonymous Oct 23, 2008
    the fax interrups incoming calls. it ring 2 times, then fax start.
How do i get a cd to install the product on my computer
Posted on Sep 05, 2008
TO NO MANUAL,
WHEN YOU DIAL A FAX NUMBER, AND IF YOU
HAVE DIALED IT CORRECT, YOU NEED TO
WAIT UNTIL YOU HEAR A COUPLE OR A FEW
DIFFERENT "CONNECTION" SOUNDS, AND
THE LAST SOUND IS THE FAX IS CONNECTED
TO THE FAX NUMBER DIALED SOUND.
IF I AM CORRECT, THE FIRST SOUND IS
A LOW TWEET LIKE SOUND, THE SECOND
SOUND IS A HIGH PITCH TWEET SOUND,
AND THE THIRD OR FOURTH SOUND IS
THE FAX SOUND, WHICH IS A SORT OF
STATIC-LIKE WHISTLING SOUND.
WHEN YOU HEAR THE FAX SOUND, THAT
IS WHEN YOU PRESS THE SEND FAXCIMILE
BUTTON.
I HAD A SIMILAR PROBLEM WITH A FAX
MACHINE ABOUT FOUR YEARS AGO.
IF THE FOREMENTIONED INFORMATION
DOES NOT HELP, YOU MAY WANT TO
RECONFIGURE YOUR FAX SEND AND
RECEIVE SETTINGS. REFER TO YOUR
OWNER'S MANUAL FOR TECHNICAL
DATA.
GOOD LUCK.
FROM
TEXASDUDE2008
Posted on Mar 14, 2008
Why won't the fax work?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Skelton Business Equipment Houston Copiers
May 08, 2014 | Sharp MX2610N Printer
Can not receive or send faxes???
If your fax machine was working before this could be a line problem. Call your fax number with your cell phone or another phone. If you get a message phone the phone company or it just rings busy its probably a line problem. Another check is to plug your hand set into the wall outlet jack, you should hear the dial tone. If there is no dial tone its also a line problem. Or just try pluging your fax machine in at another location, if it works there you know its a line problem. If its still not working its going to be one of the boards inside the fax machine. Good luck.
May 16, 2010 | Office Equipment & Supplies
I have a Brother mfc 290c. My problem is it won't send faxes, it keeps saying "no response, busy" I have a duet line. I have tried every combination in the book but still can't seem to find the solutions...
If you get the "busy/no response" message it is because the fax machine does not get a response when it tries to dial out.
Make sure you have a dial tone by pressing the "hook" button. If you do not have a dial tone, make sure the phone line is connected to LINE on the machine.
If you have a dial tone, try dialing the fax number. If you hear a recording, there is a problem with the line.
One of these two possibilities is causing the problem.
Thanks,
Pat
May 12, 2010 | Brother Office Equipment & Supplies
No dial tone when pressing hook fax is returned
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack
Apr 06, 2010 | Brother Multi-Function Center MFC-240C...
When I hit hook to send a fax I hear a click but I get no dial tone and the same on receiving a fax MP830
You only hit hook to hear the dial tone or use the machine like a speaker phone. To send a fax you press fax start. If you can't hear a dial tone when you press hook, there is something wrong with the phone line connection, or it's plugged in to the wrong plug on the machine. The phone line goes into the one marked with an L, the other with the pic. of a phone is for an additional telephone.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Status 50 on a fax estudio 45
the number is busy. Try pressing the monitor button and listening for a dial tone. No dial tone means your phone line is not working. If you have dial tone, dial the number you wish to fax and listen to see if it picks up. If you get a busy signal, or hear someone answer, that is why it's not working. If you hear the fax tones, press start and send your document. This is a way to fax that allows you to hear the whole process.
Aug 10, 2009 | Toshiba E-STUDIO 450 Copier
Cannot send fax with a proper working phone line hooked up
I have exactly the same problem! did you find a solution or reason???
Mar 19, 2009 | Brother MFC-9440CN Laser Printer
Will not send fax
Hi:
If you can not send a fax the first thing to do is see if your fax machine has a monitor button or a handset. If it does press the monitor button and see if you can hear a dial tone. If you can't hear a dial tone then your phone line is the problem.
Mar 13, 2009 | Office Equipment & Supplies
We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
Oct 30, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
122 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
