Have two Mitsubishi WD-62627 HDTV's. One will go all black and white after unit has been on a while; shutting it off and turning it back on will correct problem for a while. The second WD-62627 has seven verticle bands, each composed of eight black horizontal lines and they are evenly spaced from approximately the center of the picture over to the right of the screen. This happens whether TV is cold or warm. Any insights or troubleshooting steps would be greatly appreciated. Greg Balsley
    Genius:
  • 1,153 Answers
The first one sounds like one of two bad boards. If you get color here always(component input (Y Pr Pb) then it's the terminal 2 PCB, and if not it could be FMT board. Either way you would need further checks to make sure. For the other set i would need email for instructions, because of broad range of problems!
Posted on Mar 12, 2008
Wd 62628 lamp indicator light is solid yellow / orange what needs to be done
Your lamp cover is not installed. That is what causes the LED to light amber. Remove and re-seat the lamp cover door. There is a switch it hits to tell the TV the door is shut. This is to protect you from electrocution.
Sep 13, 2016 | Mitsubishi 915P026010 LAMP WD-52627,...
Tip
Fix for Mitsubishi WD-62627 going black and white
I found the solution to my problem and it has worked on two different Mitsubishi WD-62627 DLP rear projection HDTV's both with the same problem of the pictures going black and white after the sets had been on for about 20~30 minutes. I suspected that the color wheel might be the culprit. I removed the color wheels from both light engines and flushed out the back sides (where you can see the pulse coils in the back of the color wheel motor in the picture below) liberally with Ronsonal lighter fluid, which is basically naptha. I used lighter fluid for years in camera repair to flush out micromotors that would slow down or bind over time. The Ronsonol evaporates quickly and does not leave a harmful residue, however, I blew each one out with compressed air to make sure there was no liquid left. I then cleaned the glass on the color wheels, installed them back into the light engines, and installed the light engines back into the TV's. Both have been working fine for several weeks now. I do not claim this technique as a panacea but it has worked for me.
Greg
on Jun 09, 2008 | Mitsubishi WD62627 62" HDTV
Does the wd62628 have a factory reset button?
should be in the manual. Or you can look on line for Mitsubishi model wd62627 owners manual download.
Sep 09, 2014 | Mitsubishi 915p026010 Wd-62627/Wd-62628...
Mitsubishi WD 65737 black screen
Sounds like the back light has gone mate. Unfortunately this usually makes the tv obsolete
Dec 22, 2017 | Mitsubishi WD-73827 73" HDTV DLP TV
I cannot see football stats on bottom of screen. mitsubishi wd-62627 setting is hdmi 1080i standard. help!
either your TV or your cable/sat box(if any) is on zoom(enlarging pix). Look for buttons on both remotes that might say picture size or aspect something like that...Pressing these buttons usually cycle thru 3 or 4 size options. When in zoom center of screen is the focus and outer edges of pic are cut off.
Sep 11, 2010 | Mitsubishi WD62627 62" HDTV
WD-62627 dark pic, contr. and bright. @ full..newer bulb.
You could try to INITIALIZE the tv by doing the following:
1) turn on TV
2) from the remote press MENU 2,4,7,0 then ENTER
3) TV will state that is INIATIALIZING
4) press the RESET BUTTON on front of TV.
5) hopefully it's fixed.
Sep 20, 2009 | Mitsubishi WD62627 62" HDTV
Need to clean lenses and do manual focus/alignment of guns on a VS-5055. How do I get access to them and adjust? Thank you.
the lenses are accessable by removing lower back of unit,clean them with a damp paper towel-wipe them off with a dry one.put back back on unit.
screen/focas controls are in front of unit.remove speaker grill remove black cover using phillips screwdriver.you will see 2 sets of controls.one row is focas.one row is screen controls.red,green,blue.turn each focas control slowly to get the clearest picture for each color.screen controls are touchy(if you turn then too high unit will shut off)if the black and white picture was good i would not adjust screen controls.if it was bad turn blue and green screens down all the way.picture is now red turn green up until it turns yellow then turn blue up until it turns white
Sep 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP WD-62627 Shutting Down
I was going to say that sounds like the power side to me mate the board power board check it out before you spend any money make sure it's unplugged before you do any thing and where a earth strap ok to stop you getter a shock ok
Jul 10, 2017 | Televison & Video
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
