Question about Fellowes DM8C Cross-Cut Shredder
Where can I get new blades?
My Fellowes shredder has some plastic pieces breaking off from between the blades and it keeps jamming up.  I never run staples through it or anything other than paper, so I don't know how the parts broke off, but they have. Where can I find replacement blade units?   Thanks. Lee
  • ljutaja Apr 01, 2008
    It seems that the plastic pieces between the blades have broken off and the paper gets wedged between the blades. Where to get the plastic pieces?
  • galleycat Apr 04, 2008
    I have the same problem talked to Fellowes they said sorry no parts available for this unit
    . If its over a year old no replacement.
    Scholar:
  • 102 Answers
Usually these plastic pieces break from the machine jamming you really should call Fellowes customer service at 1-800-945-4545 and speak with them. They may be able to resolve your problem with a little more information on your unit.
Posted on Mar 21, 2008
SOURCE:
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
Paper Jammed
I have had the paper jam in my shredder which was not a Fellowes. I removed the power plug from the wall and used old dentist tools to pick the pieces of paper out of the shredding mechanism from underneath. I did not need to remove the cover. After extracting some paper try using the paper reverse option.
Apr 02, 2014 | Fellowes P70CM Shredder
Fellowes Paper Shredder PS-79Ci power switch not working -- will not turn on!
Have you looked at the shredder blade to see if anything is still there? Turn power off, check shredder blade, clear anything stuck, put back together, turn power on and try again.
Mar 05, 2014 | Fellowes Office Equipment & Supplies
Shredder blades not turning
A staple or paper clip has jammed the cutter blades.
If there is a reverse switch then reverse to free the cutter blades and remove these objects.
Mar 23, 2013 | Fellowes Microshred MS-450Cs
My paper shredder has stopped working. There is nothing jamming it - what should I do?
I had this same problem on one machine i repaired and when I took off ththe top cover it had a bad gear where it was split and it would run fine backwards, but not forward. the gear is available online. it was also
clogged with paper, which must have caused a lot of torque on the gear. they are plastic, so they will break instead of really messing something up. good luck
Jul 24, 2012 | Fellowes P-48C Cross-Cut Paper Shredder
My fellowes paper shredder is not operating. we have lifted the shredder head and fitted it back on the basket but nothing happened
Instructions
Step 1 Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
Step 2 Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
Step 3 Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
Step 4 Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
Step 5 Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
Good Luck!
Jun 19, 2010 | Fellowes P48C Cross Cut Shredder with...
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Jul 05, 2009 | Fellowes 3011001 Shredder
I have a Fellowes ps-65c shredder. If I load a piece of paper, it doesn't turn on automaticaly. If I turn on the switch the shredder runs OK in both directions. I have cleaned both sides of the paper...
its possible the sensor has gone bad
you will need to UNplug the unit , then take it apart 9 screws then gently pry it apart with a screwdriver or butter knife
you could test this with a voltmeter, one side emits a constant should have 5-12 volts across this
the other side the reciever will change its voltage when you break the signal with a piece of paper.
also ive seen chunks of plastic break off from inside and as the teeth rotate the plastic can cut the wire
Jan 18, 2009 | Fellowes 3011001 Shredder
Staples SPL-1506X
Well, despite the manufacters warning label I choose to take the shredder apart and found that one of the plastic gears was broken. Hence the motor runs, but the blades do not turn. The thing I didn't understand, the there are metal gears and plasic gears...I can only imagine that the plastic gears at one point or another are going to give. I would suggest not to void the manufacters warrenty, take the shredder back, and get one that is built a little stronger. Hope that helps.
Jul 05, 2008 | Office Depot Ativa DQ60M Shredder
Fellowes DM8C Cross-Cut Shredder Logo
323 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
midnightmove
Level 1 Expert
quennie732
gggg
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
