Question about Panasonic NN-S954WF Microwave Oven
My Microwave cuts off after 3 seconds.
I have done some research on-line and found that it might be the inverter. I also contacted a local appliance repair shop and the tech said the inverter was 99% likely the problem. So I ordered the inverted and replaced it. However, that did not fix the problem.
I do not see any lose connections, frailed or damaged wires and no components appear to be burnt.
I would really like to fix this one rather than buy another one.
Can you tell me which part actually needs to be replaced?
  • 2 more comments
  • N need Mar 12, 2008
    Rafique,
    Could you tell me please, what is the PCB and what is it's part number for my module of microwave?
    Thank you.
    Sergio,
    According to what I am seeing, page 57 is in Spanish. I don't read Spanish that well. Would you mind translating?
    Thank you.
    Sergio,
    Thanks for clearing the up. I'll order the part you suggested (F603L6G40AP). It will be a few days before I will receive the part. If that fixes the problem I will Accept the answer as problem resolved.
    Thank you.
  • N need Mar 31, 2008
    Rafique,
    I changed the PCB and it did not fix the microwave. I have replaced not both the PCB and the inverter. And it still doesn't work. I am going to have to buy another microwave now. I have already put to much money in this one. How do I obtain the refund?
    Thanks.
    President:
  • 1,314 Answers
Look i don't want your cash ok there are a lot of theese micro waves under recall right now sounds like a thermal switch problem lets chat ok tell me exactly what happing whats the setting and whats going on are you hearing a loud buzzing is any sparks arching there is a thermal switch might be causing your problem but don't replace any thing else and certainly not the power control board or pcb tell me everything your noticing and keep your cash
Posted on Mar 31, 2008
  • robert samples Mar 31, 2008
    you can e mail me at [email protected],com if need be
    have you tried plugging this unit in another outlet and have you checked for a voltage drop in the outlet
  • 813 Answers
Hi friend
i read ur problem its a timer curcuit poroblem so u have chenge ur timer ic if u not have any idea so go with a good tecnision its better for for both ur prodect & for u 2 if u not proper knowlage of the eupipmet then u shoud to see a good tecnision he will guide u how to do this but if have do more damge in ur microewav its so doing repait its too costly do not exriments get microwav with good tecnision or a good reparior
or
if u have warrenty pedior then u have to replace ur product aby the compny
& thnx to using fixya
    Brigadier General:
  • 3,614 Answers
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; and contact a service technician to do the work.
  • micromaster
    micromaster Mar 31, 2008
    There are some parts you can work on yourself if you're mechanically inclined - and even if you can't fix it yourself, it's good to understand what the problem is before you hire a pro.
    1. Unplug the power cord before opening up the oven cabinet.
    2. Check the cord, fuses, fan motor, door latch and timer if the oven won't run. Safety devices are built into the oven at all of these points and will prevent the oven from working if they are faulty.
    3.Suspect the thermal cutoff, capacitor or transformer if the oven runs but isn't heating the food. If the problem isn't constant, check the door seal, timer, control panel and all of the wiring.
    4. Test and replace the door monitor switch or capacitor if the oven fuse keeps blowing.
    Hope this initial check would help..
    EnJoy..
  • 818 Answers
I see this where you can download the guide and the other where you can order the part of exchange that missing.
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Countertop-Microwaves/model.NN-S954WFB.H see page 57 can be useful.
http://www.pasc.panasonic.com/Epartr/PartsList.asp
Sergio
Posted on Mar 12, 2008
  • 1 more comment
  • Anonymous Mar 12, 2008
    F603L6G40AP
    PC BOARD W/COMPONENT
    34.23
    sorry page 27. i missing it.
    Sergio
    i'm wait
    see you soon.
    Sergio
    Sergeant:
  • 406 Answers
Please change the PCB of your Microwave Oven.
SOURCE:
Model 72180883400 Microwave Oven F-9 Failure Code
If the unit is less then 5 years old i believe it is still covered it may be the inverter board or a grounded Magnetron tube. If you need any further assistance let me know. I would contact kenmore directly.
Thanks,
Lee
Sep 01, 2008 | Kenmore 62702 Microwave Oven
FMV152KWA microwave buzzes when not running
Missy Uhland Bauman,
I understand that you are hearing a buzzing noise from your microwave, even though the door is shut and and it is not running. I would suggest to give the appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back. If you are still hearing a buzzing sound, I suggest either contacting the manufacturer or your local authorized technician.
-Best Regards-
Jan 10, 2014 | Frigidaire FMT118E1B Microwave Oven
Kenmore elite model #665.61683101, has no power, plug works but microwave has no display, is there a fuse in this model?
There is a line fuse for this oven. Remove the cabinet and the fuse should be close to the line cord. Replacement fuses should be found at your local appliance supply house.
Apr 19, 2011 | Kenmore 62622 Microwave Oven
Microwave
Hi
3 things can fail - the control board, the inverter board, or the magnetron. If the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
If this is not the case then it could be a defective control board, inverter or line voltage too high.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 26, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
F-9 Error code
The F9 error code indicates a failed inverter. If resetting the unit does not help you will need to have the inverter & harness checked.
http://media.fotki.com/1_p,wbgdfgsrsttwqwbxgtqsskgwtqkq,vi/kgdfkfrkkxkfdtftrfb/1/1303472/5961857/image45625img-or.jpg
This can sometimes by caused by a power surge or glitch through the electrical lines.
You can sometimes clear this fault by completely unplugging the microwave for 1 minute.
Plug it back in and see if the fault code returns.
If it does, then you have an internal component failure that will need to be serviced by a technician.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances.
Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged.
A microwave radiation leakage test must be performed on the unit following any internal component repair.
It does not ALWAYS indicate a inverter control board problem however in other brands/models.
LG's service manual (for an example) suggests the f-9 code could be due to line voltage, magnetron, inverter module, "Relay2", or a loose connection between door/magnetron/control pcb.
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case.
For example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possibilities.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 17, 2009 | Kenmore 80809 Microwave Oven
My panasonic microwave model NN-A574SB keeps cutting out after 5 seconds. Is ther anything I can do to fix this? Do you know why it is automatically cutting out? Any diagnosis would be gratfully...
Could it be 3 seconds?
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 05, 2008 | Microwave Ovens
Microwave turns off after 1-2 seconds
It turned out to be the three door attachments that weren't lined up. It has been fixed. We almost bought a new one because Samsung referred us to a service that would have charged way too much to be worth it even thought the machine is only 3 or so years old. Luckily, we looked further. A local independent appliance fixer came to the house and took care of it within a few hours of my call! Yea!
May 29, 2008 | Samsung SMH7174BC Microwave Oven
Microwave cuts out after 23 secs
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Dec 15, 2007 | Panasonic NN-S550WF Microwave Oven
Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Dec 26, 2006 | Panasonic NN-S950WA Microwave Oven
Panasonic NN-S954WF Microwave Oven Logo
231 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
