Question about Bosch Axxis WFL 2060 Front Load Washer
Part number Where can I locate the part number on a bosch axxis washer motor
    President:
  • 1,294 Answers
Go to> espares.co.uk
or > RepairClinic.com
Posted on Mar 16, 2008
SOURCE:
Bosch axxis 2090 motor
If it's the motor, then you should definitely check the troubleshoter within the manual, you can download it under this article:
Bosch Axxis Washer Manual
Dec 31, 2013 | Bosch Axxis WFL2090UC
Need instructions to stack Bosch Axxis washer & dryer - 24"
You can find the manuals at this link
http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html
Dec 22, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Washer, not spinning. Belt looks ok, front filter removed and cleaned. Previous answers say motor brushes, how are these looked at? Access through the back, would prefer not to take...
IF THERE IS BLACK DUST UNDER THE MOTOR IT IS USUALL DEAD. YOU CAN REMOVE MOTOR FROM THE BACK I HAVE DON IT. YOU NEED A METER TO CHECK THE MOTOR. I CAN HELP.
Apr 25, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Replacement front door for a Bosch Axxis WLF 2060
Visit repairclinic.com. Enter your model number in the search box and it should call up the parts you need.You'll be able to see actual photos of the parts on size grids so you can compare with what your's look like.
I did a quick search and it looks like you're looking for part number 1046685 .
Dec 14, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
May 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Washer fills and will drain but not wash.
i remember click is the motor relay engaging.
reason for no rotation may be the motor brushes.
take back panel off, disconnect motor elec plug, undo fixing bolts and withdraw motor and you can then check brushes. also check condition of commutator - series of copper segments brushes run on
Sep 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Aug 27, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Power to washer is on, but display not responding
maybe door not closing correctly
try a bit of crc in lock to lube otherwise controller shot and brushes worn out in motor
Dec 31, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
48 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
