Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
Dead motherboard on emachines t2984
I have a emachines t2984 that wont power up. Took it to local shop and was told that the motherboard had to be replaced. I thought it was the power supply but they installed a new one and still didn't power up.
I'm not really sure it's the motherboard. What else could be wrong?
  • 8 more comments
  • ljbltd Mar 12, 2008
    how can i fix a bad power switch?
    It's not the power supply. It's the motherboard. Where can I get a replacement? What should I look for?
    Thank you in advance
  • Sooty99 Jun 16, 2008
    I have an Emachines t-2984. It just shut down when it was up and running and will not start up. I suspect that the power supply went out, however after reading about the power supplies, does anyone know what the chances are that the mother board did not fry? I hate to waste the time or money on a computer that I am not going to replace the mother board on. However if there is a chance that it is just the power supply, it's worth it to try and get it going.
  • checchelin Jun 22, 2008
    I replaced the power supplay in the eMachines T2984 and have a green led on the motherboard turn ON. but the computer not turn on when I press the
    from button.
  • 512kent Oct 17, 2008
    I have the exact same problem. The computer quit working. I replaced the power supply, and now I only get a green LED on the board. I have contacted both Intel and eMachine, and neither want to do anything because it is out of warranty. I am thinking about buying a replacement motherboard off ebay. Does anyone know if this will fix the issue, or will I be wasting my time and money?
  • vomommy Dec 06, 2008
    My T2984 was running perfectly, then after I turned the unit off one day it just wouldn't come back on. Nothing. Not a hum, or a flicker, or anything. I thought it was the power supply so I switched it out and there is that little green light but nothing else. Has ANYONE figured this out? Does this sound like the motherboard? Have I lost all my data? Uggggh!
  • Anonymous Jan 03, 2009
    My power flickered in the house, the computer went dead and now cannot be turned on. I tried a new power supply and same thing regarding the small green light. Power button does nothing. Is there any detail regarding this capacitor that goes bad or does the mother board need to be replaced?
  • junkEachines Feb 03, 2009
    4 yr old T2984 working ok until pwr company dropped power. Even though the computer was plugged into a APC UPS, the computer would not come on when the power was restored. Just the infamous "little green light" everyone else has experienced. A specialized service shop looked at the machines, did all their magic (claim they can fix motherboards...in this case the Intel Seabreeze) but no-go. Capacitors or CPU not problem. Diagnosis> dead component somewhere in motherborad. To costly to get into MB repair. Total junk. This baby will not even make a good boat anchor for a small canoe.
  • Anonymous Feb 06, 2009
    Same problem! T2984 found dead after my wonderful husband shut off the electricity a few times to install electrical in another part of the house. Replaced the power supply & got a green light, but nothing. Replaced the motherboard, nothing. Anyone know where to find a new power switch wire??
  • myfam Feb 20, 2009
    This same occurred to my sister in summer of '08
    Is anybodys system still under warrenty with E-machine? mine is not, i tried the emachine support and got hung-up on twice - they referr to it as call disconnected. I'm going the intel route to see if i get any further. This is too many people with the same machine and the same problem to be chance.
Contacted emachine and they are completely denying this and told me that since the warranty is out of date, there isn't anything they can do. Never was any recall on this model.
Posted on Apr 08, 2008
It's not a power switch or a power supply failure, a capacitor has gone bad. I have the exact same problem with another eMachine, the T2984's have been recalled due to residue buildup in their capacitors which results in a failure to turn on. here's the artice..
http://www.intel.com/cd/channel/reseller/asmo-na/eng/tech_reference/box_desktop/int_inst_info/dsk_factory_notes/193414.htm
    Genius:
  • 1,601 Answers
I hope that you took it back to them.
Have them check the power supply, too. Besides, a bad power switch and connections that would be the only thing that would be keep it from starting.
Posted on Mar 12, 2008
  • Thomas Christopher
    Thomas Christopher Mar 12, 2008
    You will have to take it out to see which part of it is broken.You may have to replace it
    You should be able to fit any ATX board in the case.
I am having he same power up problem. Not the power supply - checked with a different supply. Bypassed the on/off button and that did nothing. Tried clearing the CMOS by removing battery and moving jumper near the battery. That didn't work either. Any other ideas?
Posted on Jul 19, 2008
I am TOTALLY suing the Hell out of emachines!!
Not only did they cause me IMMENSE and inexplicable amounts of emotional and mental distress, but financial as well!!!
I have a T5082 and the power supply went out, replaced that and then 3 days later it won't turn on at all!!
GRRRR!!
I NEED my internet, not only that, I have a 2 and 4 year old that use it so they can learn and get off my back as well!
I also have Vista (Yuck, I know, but this is our 1st computer and I didn't know any better!!) For God's sake!! The transmission wento out on the car, the only other T.V. is broken, I can't really leave or watch anything, I'm a frickin' bored *** prisoner over here!!
What isn God's name do I do?!?1
OH! I am also EXTREMELY BROKE and have to use the damn library internet with their stupid time limits!!!!
Posted on Nov 06, 2008
SOURCE:
IM connecting a OKIA LC-8460BTX POWER SUPPLY TO MY EMACHINES T2984. I cannt figure out where the wires are placed.
There should be a photo of the board and instruction on where the leads are fitted if you browse the manufacturers web site and input the model of the unit you are refitting.
I have found this site, which may be of use to you. Regards.
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/302350-e-machine-t2984-motherboard.html
Jan 04, 2011 | E-Machines eMachines Refurbished EMA...
Wont start emachine 4260
FIRST OF ALL NEVER GO INTO BIOS UNLESS YOU KNOW WHAT YOU ARE DOING!SET YOUR BIOS TO DEFAULT SETTINGS,I HOPE YOU DID NOT TRY TO OVER CLOCK YOUR COMPUTER.SO MY ADVICE IS TO TAKE IT TO YOU LOCAL COMPUTER REPAIR SHOP AND TELL THEM YOUR PROBLEM AND THAT YOU WENT INTO BIOS.HOPE THIS HELPS BYE
Nov 27, 2009 | E-Machines eMachines Refurbished EMA...
T2984 won't power up
I've re[lace alot of bad eMacines power supplies. Nearly all of them took out the video chip on the mother baord, rendering it useless.
Mar 23, 2009 | E-Machines eMachines Refurbished EMA...
2 emachines won't boot
Are you attaching them properly
if so then it is something other then power supply
something has caused both power supplies to blow
have you installed anything in the first emachine you talk about
Jan 17, 2009 | E-Machines eMachines Refurbished EMA...
I have an emachine T2984 that won't boot. No noise of any kind. I had another emachine T2625 that was working. I took the power supply out of the T2984 (that wouldn't boot) and put it in the T2625 and it...
Power supply sounds fine. If the pc won't power up it could be your motherboard. If the pc is powering up and you get a 'no signal' on your monitor it could be your gpu.
Emachine T2984 won't power up
First, Check your ram. If not seated, it will not power up. Also, do you hear a series of beeps or not? Need a better & more exact description of problem and what occurs
Apr 14, 2008 | E-Machines eMachines Refurbished EMA...
Emachines t2984 that wont power up
Make sure the RAM is seated properly and recognized by the coputer bios program.
Mar 25, 2008 | E-Machines eMachines Refurbished EMA...
Where can I get a replacement motherboard for emachine T2984?
Here is a site where you can buy one for a relatively good price....hope it works out.
Mar 12, 2008 | E-Machines eMachines Desktop PC
Motherboard manuel
i need manual for motherboard 14319 imperial_gv 20030812 thankz
Dec 25, 2007 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
2,898 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
