Question about Crown CE1000 2-Channel Amplifier
Sensetivity switch and bridging
First of all I use my system for dj/karaoke applications.
What does the sensitivity switch do? where should it be set?/
also, I am going to bidge this unitand it has Speakon jacks, do I need to buy a y type adapter??
  • 682 Answers
Sensitivity switch select best position of the input level to get full power when you set level control at maximum. in your situation 26db position is better.
Posted on Mar 12, 2008
What inputs do I use to connect my laptop to the gemini cdm 3700g?
if it's to record the Audio you need some kind of interface analog(RCA ) to usb like the behringer UCA 202 Now if it's to watch or to try to record Audio and Video you need to look at a video capture type of interface composite audio video to interface like the SIIG USB 2.0 Video Capture Device just make sure its compatible with your OS. Now if you try to use it as a Midi controller with program like Serato , Virtual dj ... you are out of luck this system is not compatible .
Good luck.
Jul 05, 2014 | Gemini DJ Gemini CDM-3700G Dual CD Karaoke...
What should i set the micro switch on the back at?
Power:
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
Vocopro 8900 noise but no music
No power to voco pro 8900 cd player
Aug 09, 2012 | Music
How to connect a numark cdn25+g
This should help:
http://www.numark.com/images/product_downloads/cdn25_quickstartguide.pdf
You do need an amp.and a mixer. You mixer should have microphone jacks, and a pream or switch to allow you to use lowZ, High Z or amplified microphones.
Mar 29, 2012 | Numark CDn25 Professional DJ CD Player
The touchpad is too sensitive and light pressure will cause it to activate it complete a command.its annoying because i have sent 15 messages before i could anyfin about it.I have the bold 9700
There is a Swipe sensetivity within the settings portion of your phone that you should be able to lower. Lowering the sensetivity here should help with it being activated when it shouldn't be.
Mar 07, 2011 | Cell Phones
Does the intect wii karaoke microphone work with dj hero 2?
Where dose the microphone get plugged into?? ur tv?? or what because i dont know where too plug it into..
Oct 23, 2010 | Intec Wii Karaoke Microphone
I cant connect my pc to my mixer for karaoke
Ronnie, The numark mixer will not project CD+G graffix on the pc. You can only send the audio from the mixer to the pc. To use karaoke on the pc you need files that re MP3+CDG or CD+G discs. Most karaoke systems only support TVs through a video line usually RCA connections. In order to get video to your PC you need a video card or TV tuner card installed. Most people use it in the reverse having their music files on the PC and then streaming to the mixrer and then the audio speakers. Winamp with MEXP and the CD+G plug installed should work nicely for you. Let me know if I can help further I have been a mobile DJ for 20+ years
Joe
May 25, 2009 | Nu Mark Numark Cm100 4-Channel DJ Mixer...
Crown CE1000 2-Channel Amplifier Logo
73 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
