Replaced lamp but power light keeps blinking Red and the TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Tv turns on but you dont see the picture then it turns off. i just keep trying til it come on .Then when i have finished watching tv i turn the tv of and it flashes 10times in 3 second intervals
SOURCE: tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
SOURCE: just replaced lamp. when plugged in, power light
hello make sure the lamp is fitted securely and the lamp cover aswell
regards
shaun
SOURCE: Lamp or power?
Thats a lamp switch error. You need to keep trying to reseat the lamp till it goes away.
I will look at it when I get home tonight. Yes it is a constant red blink after the green light stops blinking from trying to turn on. Thanks you so much for your advice.
