Question about KitchenAid KESC300 Electric Kitchen Range
Large Burners do not re-ignite
We've had a 6 burner kitchen aid stove (gas and electric)
just recently my husband replaced the porcelain black top because it was all scratched..etc. We ordered the part and he did it himself.
Now, we've noticed that once I use any of the larger burners 1x, and I shut it off and go to use it again within a 10 minute period or so, the gas goes on but there is no clicking to ignite it again.
any thoughts?
    Novelist:
  • 131 Answers
When you are having trouble igniting that one burner, have you tried the other burners?
If they're all the same - i.e. none of them will work at any particular time, that's the spark module.
If some work while one or more don't, that's the burner switches under the knobs.
I doubt this has anything to do with your husband's previous repair; that is, unless you find one of these wires pinched inside.
Posted on Mar 12, 2008
SOURCE:
Can the cooktop surface of my Kenmore gas range model 790.72903011 be removed
Most stove tops are removable for that very purpose.... after you remove the burners and the grills above the burners.... look for an edge and inch or inch and a half below the top... get something strong like a large screwdriver and place cloth over the tip to prevent scratching the stove top. there are VERY STRONG CLIPS holding the stove top to the stove, pry upward until the clips release. then slowly remove the spark igniter (TAKE A PICTURE WITH YOUR CELL TO REMEMBER HOW PUT BACK TOGETHER)
Jul 30, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Own a KitchenAid gas range superba, how do i clean the burner, one of my front burners the gas flow is very low, the stove has the glass/ceramic top with no wells & no way to get to the burners...only...
You'll need certified stove technician to service you kitchen Aid range. You have low gas flow on one of the burner. The manual gas control valve behind the knob needs to removed and cleaned. If you have one cleaned then have technician clear all four of these manual gas valves. While he cleaning the valve have do a complete check up of you Kitchen Aid range. Dangerous for the home owners to do this procedure because flowing natural gas or propane. In a lot the states you'll need to be certified by the state to work with natural gas, gas stove, ovens, gas home heating units, etc. It differentially a no,no here.
It is not the burners, it is gas flow valves for the burners. Most of the burner are made of aluminum and I wouldn't use any harsh cleaners of them. Check with Kitchen Aid and ask them what is recommend for cleaning the burners. Also the top of the range isn't ceramic but porcelain, it glass that has been melt to the top hood of the range. Don't use scratch pads, steel wool or any thing that will mare the Periclean surface of your stove.
If you can get the aluminum burner out to clean them then do so. GB you Allison and I wish you many year cooking on your Kitchen Aid range. stewbison
walk softly up on this earth and she will good to you...
Aug 21, 2011 | KitchenAid Kitchen Ranges
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
None of my stove top burners will spark to ignite
There is an ignition module that sparks when it calls for lighting. This module could have a loose connection or be dead.
Apr 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
Conversion from electric to lp gas
Simple answer NO.
Unless Jenn-air has a conversion kit. (highly doubt this)
It would be a serious undertaking to switch out 2 burners for LP use.
Gas tubes, igniters, electronics, regulator, gas jets.
Not to mention the modifications changes needed to the stove top to make all this work. That gas regulator has to go somewhere and piping from tank/regulator/burners.
Not saying it can't be done mind you.
But think about it long and hard before committing to this job.
Small gas leak can become a huge headache later.
Oct 04, 2009 | Thermador PGR366 Gas Kitchen Range
Range top ignighters sparking
One of your "switches" to your burners is shorting causing unit to spark when in the off mode, or, you may have a bug problem, bugs have made their way into the spark module.
1: if no bug problem, disconnect stove from electricity, lift top up, remove all of the single connections to each switch to top burners(make sure they don't have any bare wires touching the frame), then plug unit back in, if still sparking then replace module.
Oct 01, 2009 | GE Profile 30" Self-Cleaning Slide-In...
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
Oven won't work on gas with electric ignition stove
The glow bar for the bake burner is bad, needs to be replaced. Remove oven bottom to get to it, and also the utility drawer.
Feb 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Kenmore Elite Gas Stove
Will have to ask some basic questions first.  How old is the stove?  What is the entire model # from the sticker on the unit?  Is this LP or natural gas?  Also, make sure that the orifices in the center of the burners are clean (can use a safety pin or paper clip to poke them a few times to clean).  Make sure that the black caps are on top of the burners and seated properly or they will not lite.  Let me know what you find.
Oct 16, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
KitchenAid KESC300 Electric Kitchen Range Logo
145 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
