On a Moen Faucet the set screw is behind the little "blue and red plastic tab", remove this tab very carefully with a small flat screwdriver. Then you should be able to see the set screw. make sure to turn of the water supply under the sink first. The set screw will probably be an "allen head" type and you will need an allen head wrench. This is a hex shaped 6-sided tool in a rod shape and is available at your local hardware in a set. Next you will need the model # of your faucet and take this to your local hardware to match with a repare kit. Moen usually has a lifetime warranty and if you have your paperwork just call Moen directly and they will send you a free replacement kit, free shipping too. The kit has installation instructions with it.
I have been told,that I have to take the whole thing apart from under the sink, how crazy its that?
what do you mean by gasket?is the faucet leaking?if so from where?
Removing a 4 inch bathroom facuet
