Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Checking electrical components--Mitsu WS 55513
Hi... I got a PDF file service / schematic manual for the Mitsubishi WS-55513 and will try and follow your guide. Am I looking on the main power board or the secondary power board for these Pico Fuses and Limiting Resitors? The schematic is so **** small, and my eyes arent what they once were..
LOL
Thanks in advance...
-Richard (MetalDad)
What you are looking for are green resistors. there will be about 5 or 6 of them on both the right side pcb and the pcb in the middle. they should have no resistance. The one or ones that are open will point you to the circuit you need to check.
Posted on Aug 21, 2008
    Scholar:
  • 167 Answers
Hello the power supply board is to the right of the set . when you are looking at it from the back.!!! how you will know is the fly back transformer will be there, it will be black in color & will have 3 to four red wire's comming out of it.!!! there are 3 fuse on that board . !!!! they look like a regular fuse .!!! but just smaller in size.!!! they should not be hard to find.!!! you might want to get your self some glasse's to help your self see better.!!! well a"good luck" hope this help's you.!!
Posted on Aug 20, 2008
SOURCE:
Mitsubishi WS-55807 Error Code 24 Vertical Deflection Failure. 5.
Hi. The service manual is in more than one part.
Schematics are in part 2 here:
Download Service Manuals for free
Jul 30, 2016 | Mitsubishi WS-55807 TV
Mitsubishi WS-55513 won't power on.
there is an electronic problem inside the tv you shoud go to an authorized service because the power supply to this tv it is in protect mode somehthing hapened inside and need to be repair
Dec 11, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Code 21
Its very frustrating when we think we have something fixed and then forget to do something or hook something up wrong to only make what seemed like a simple repair much more complex...Here are a couple manuals if you don't have them that will help..Not sure if the last are the same as your TV but thought I would post them all in case they are...Good luck!
Mitsubishi Electric WS 73513 Service Manual Mitsubishi Electric WS 48513 Troubleshooting Manual Mitsubishi Electric WS 48513 Service Manual
Feb 10, 2018 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-55513 blinking light
Try first unplugging power cord for one hour.
Oct 06, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Board Repalcement
HI,
You can try partstore.com or appliancepartspros.com
Jun 14, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-55513 blinking power light
The infamous flashing green LED problem is usually due to a failing or faulty DM board. I purchased the PDF manual online and was able to locate and remove the components as necessary.
If you can solder, and are semi-proficient with electronics it is 4 bad capacitors on the DM board...
Otherwise there are facilities that can repair your failed board for about 275.00 or replacement of the board is between 350.00 and 500.00 buck USD.
Good Luck with your repairs....
-Richard (MetalDad)
email: [email protected]
May 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS 55513...
www.chrisandnat.com/projects/blinkingtv/blink.htm
Also,check three 4 amp surface mount fuses on trace side
of board.............T.
Mar 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS 55809 Rear projection TV
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Jan 16, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Blinking Light Problem on Ws-55513
If bad capacitors are the problem then replacing them will involve soldering.
If the problem is something else less visible then fault finding will be difficult without the proper service manual.
http://www.completeservicemanuals.com/mitsubishi/crt-projection-television/ws-55513-service-manual/prod_37.html
This will show the correct disassembly and test procedures.
Good luck.
Oct 20, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
