Question about Casio EXILIM Card EX-S770 Digital Camera
Won't turn on, and heats up quickly when battery is put in.
Camera was fine. The odd problem of not turning on, but usually rectified by removing and reinserting battery. However, today, was working normally, put it into cradle to recharge, and now it won't turn on, so removed the battery, reinserted it, but still won't turn on and it heats up very very quickly when I put the battery in - noticeable immediately, and becomes too hot to handle in about 2 minutes. Have removed the battery (as am afraid of fire!), and am camera-less. Any ideas?????
  • 374 Answers
You need to contact the repairs dept and tell them whats going on. DO NOT LET THEM TRANSFER YOU TO TECH SUPPORT! THey like to do that. Tell them you want someone from there in the corporate office to contact you.
Posted on Apr 05, 2008
SOURCE:
Frozen camera
And after removing the battery, you first charged the battery before reinserting it?
Because when a camera suddenly stops, most of the time the battery is empty. At least it does not have enough power to work safely.
Try charging the battery, and reinsert it. Then I hope everything will look different.
Still it could be the battery is not in working order, but you should notice a different behaviour when charging it. If it almost takes as long as normal to charge the battery it should be ok.
Feb 09, 2014 | Nikon Coolpix S3300
Camera wont turn on
Very odd that both cameras would stop working at the same time, has someone else abused them?
Removeing the batterys for a while is a good enought reset, check the battery connectors and contact your dealer if they both have warranty you will get them repaired or replaced for free. other than that I can recommend you a repair man if you provide me the city you live in.
Jun 12, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Error message "turn power off and on again" I did this and it did not work.
Performing a manual power reset (If your camera does not have reset button and initialize function)
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jan 07, 2014 | Sony Dsc-s2000 Cyber-shot Digital Camera...
My samsung pl120 won't turn on
You need to get fresh batteries in hope it will power on.
Mar 19, 2012 | Samsung PL120 Digital Camera
My Lumix DMC-LX5 camera won't turn on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Panasonic Lumix DMCLX5 Digital Camera
I have a D5000 camera w/ kit lens VR 55-200, less than a year old. Recently and only occasionally what is happening is when I press the shutter release button, the lens won't focus, it won't move...
Your camera is still under the one year Nikon warranty. Call Nikon's repair depot at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They will verify your warranty and assist you in returning it for repair.
Jun 08, 2011 | Nikon D5000 Digital Camera
My camera automatically turns off and won't turn back on when i use the flash. the only way i can get it to turn on again is by putting the battery back in the charger, this also happens when the...
it would appear the battery is "weak" and needs to be replaced. although testing it with a battery tester may show it is fine. when you turn on the camera you are putting the battery under a load and the voltage may drop too low. quick test would be to test the battery voltage after you take it out of the charger and then again after you have used it to power on the camera. ebay would likely be your most inexpensive source for a replacement battery.
as a side note i suggest you go to the canon website to find out if there is a recall on that particular battery. i realize this is about camera's but my garmin gps battery was recalled (and the gps was about 4 years old) and it was replaced for free.
May 09, 2011 | Canon EOS Rebel XSi Digital Camera
I recived the Nikon Coolpix S6000 in December. It has been working fine up until today. It will not turn on.. I have charged (which the light does show its charging), removed and reinserted the battery. I...
Have you tried checking if the battery door is completely shut and flush with the body of the camera? Try cleaning the contacts where the batteries touch and make sure that there isn't any dust or dirt obstructing the plates. If your camera still doesn't turn on, the battery has probably short-circuited or fried. You can easily order another one for under $10 via Amazon here:
Good luck.
Apr 03, 2011 | Nikon COOLPIX S6000 Digital Camera
Casio EXILIM  Card EX-S770 Digital Camera Logo
59 people viewed this question
Top Casio Cameras Experts
Ekse
atollminsk
Level 1 Expert
Parshiv Luthra
Are you a Casio Camera Expert? Answer questions, earn points and help others
