Keyboard led how do i manually take out the led from the keyboard? i see that i need to unscew everything under the board and i might mess things up...
  • Anonymous Mar 12, 2008
    wow. greatly appreciated. i wont start doing this til i buy the leds though. thanks a bunch for that quick input. btw, im using a standard keyboard. not a wirelesss one.
    btw, are you really a girl? you look kinda cute... never thought an expert to be a woman.
  • 871 Answers
That would be a messy job indeed. but you can do it. all you need is to be careful enough. try to unscew the keyboard and arrange everything according to the way you dismantle it. be very careful with the rubber housing for your keyboard as this will affect the way you type.
look for the small board which has the leds soldered to it and start the unsoldering from there. after doing the led changing, replace everything back as the way that you put it. just be sure that you are able to arrange everything the way that it should be.
hope this helps.
Posted on Mar 12, 2008
SOURCE:
MY DELL PC BEEPS 6 TIME, SHOW AND KEYBOARD ERROR AND DISPLAY A ORANGE LED AT THE MOTHER BOARD
The Dell user manual has the beep codes, which usually are in sequences with short pauses between. To figure out the problem one needs to know the spacing of the codes. Is it 1-2-3, or 2-2-2, or 3-1-2 or what? The first thing I would check is the RAM - make sure it is seated correctly, and try removing all but one stick.
Jun 24, 2014 | Dell OptiPlex GX620 PC Desktop
Macbook screen is zoomed or magnified too much. How do i reset it?
Accessibility Zoom?
If everything is messed up and not just one app, you may have managed to switch on accessibility features and triggered the zoom. Does the screen scroll around as you move the cursor?
As all of the controls are customisable, some things may not work but try <option><command><minus> to zoom out.
Go to System Preferences and select Accessibility. Choose Zoom on the left and uncheck 'Use keyboard shortcuts to zoom' and 'use scroll gesture...'.
Otherwise, some of the other suggestions should help.
Mar 27, 2014 | Apple MacBook Pro Notebook
My console keyboard is locked up
The keyboard cable is likely messed up, but things break. Id use a USB external board, or order a new keyboard for that machine.
Jan 24, 2010 | Dell Latitude C610 Notebook
Need to replace keyboard in HP Pavilion dv6626us Entertainment Notebook PC. thanks
Turn the computer off and close the computer lid.
Remove the battery and the AC power supply.
1st we need to remove the switch cover or keyboard bezel. This is plastic strip that runs above the keyboard.
Turn the computer upside down with the front panel towards you.
Remove the three Phillips screws that secure the switch cover to the computer.
Turn the computer display-side up with the front toward you.
Open the computer as far as possible.
Lift the rear edge of the switch cover and swing it forward until it rests on the keyboard.
Release the zero insertion force (ZIF) connector to which the LED board cable is connected and disconnect the cable from the LED board.
Remove the switch cover.
Now remove the panel directly above the battery compartment and remove the 2 keyboard screws there and another 2 screw in the battery compartment (they should me marked with icons of keyboards)
Turn the computer display-side up with the front panel towards you.
Lift the rear edge of the keyboard until it rests at an angle.
Slide the keyboard back to disengage the tabs on the front edge of the keyboard from the top cover.
Swing the keyboard forward until it rests on the palm rest.
Release the ZIF connector to which the keyboard cable is connected and disconnect the keyboard cable from the system board.
Remove the keyboard.
Just reverse the procedures to replace everything.
Good luck.
Sep 17, 2009 | HP Computers & Internet
Laptop keyboard not working when LED Power board is connected.
I agree. Your best bet if you don't know what you are doing is to find a repairer.
Jul 07, 2009 | Intel 430180-001 - HP Pavilion dv8200...
Stuck caps lock condition -- even if caps lock LED is off
disasemble the key board and clean it very well unplugged from pc of course..keyboards can go quick with a slight drop to the floor and will mess up buttons..walmart has them for 15 or 20 bucks..if all else fails.
Jun 09, 2009 | Apple Computers & Internet
Mouse and keyboard all crazy
This is a minor problem..
Just plug out both mouse and keyboard and again plug-in..
This will solve your problem..
Mar 19, 2009 | Micro Innovations KB1045LSR Keyboard
Casio CT-670 Tone Bank keyboard completely dead
How familiar are you with schematics? I've just found my CT-670, There where marker marks on the keys. I cleaned it up. I took it apart as one channels had no sound. I love this machine. I want to find a manual for it also schematics would be very helpful for me too.
I would suggest looking inside for burns on semiconductors. or loose soldering. I need to replace a chip that has no cross reference... that I've found yet... I think it's an amplifier but need to spend more time on it....
Mar 14, 2009 | Casio Music
Donot startup
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Restart the system.
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 15, 2008 | Acer TravelMate 2300 Notebook
Booting problem
you try to reset the bios , look if the board have any jumper for this ,also could be that your friend mess up the bios in some way i hope this be helfull
Sep 12, 2007 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Open Questions:
MALWAREBYTES cUsToMeR SuPpOrT PhOnE I:855:,:5365666 NuMbEr .U.S.A AsIf This MALWAREBYTES aNtIvIrUs USA phone number is ranked #2 out of 2 because 7,728 MALWAREBYTES aNtIvIrUs USA customers tried our t55ls and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the MALWAREBYTES aNtIvIrUs USA customer Support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, MALWAREBYTES aNtIvIrUs USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. MALWAREBYTES aNtIvIrUs USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact MALWAREBYTES aNtIvIrUs USA with help from customers like yourself. Please help us continue to grow and improve this information and these t55ls by sharing with people you know who might find it useful. Calling MALWAREBYTES aNtIvIrUs USA Calling MALWAREBYTES aNtIvIrUs USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back t55l. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from MALWAREBYTES aNtIvIrUs USA customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with MALWAREBYTES aNtIvIrUs USA's customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare MALWAREBYTES aNtIvIrUs USA's phone numbers against each other. Contacting MALWAREBYTES aNtIvIrUs USA in General While I********** is MALWAREBYTES aNtIvIrUs USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to l55k at as well. One thing to keep in mind as you try to reach MALWAREBYTES aNtIvIrUs USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact MALWAREBYTES aNtIvIrUs USA.
Oct 19, 2019 | Best Computers & Internet
Aol phone number for password reset~18OO8O31-O69 dcgl Usa AOL USA phone number is ranked #2 out of 2 because 7,728 AOL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO::8O31069 is to reach t he AOL USA Technical support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, AOL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL USA Calling AOL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL USA Technical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL USA's Technical support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL USA's phone numbers against each other. Contacting AOL USA in General While I8OO8O31O69 is AOL USA's #2 most popular phone number, it's not the only way to get a hold of their technical support team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL USA help by calling them, is that other customers give their technical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL USA.
Oct 19, 2019 | AOL Computers & Internet
AoL technical sUpPort pHone~18OO8O31-O69 nUmbeR cgl Usa AOL USA phone number is ranked #2 out of 2 because 7,728 AOL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO::8O31069 is to reach t he AOL USA Technical support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, AOL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL USA Calling AOL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL USA Technical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL USA's Technical support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL USA's phone numbers against each other. Contacting AOL USA in General While I8OO8O31O69 is AOL USA's #2 most popular phone number, it's not the only way to get a hold of their technical support team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL USA help by calling them, is that other customers give their technical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL USA.
Computers & Internet Logo
250 people viewed this question
Ekse
Alun Cox
