Question about Motorola Mobility MOTOROKR E6
Side key lock
My phone"s side key lock is damaged
what can i do
  • 7 more comments
  • alfeche91 Apr 03, 2008
    Hello, every time I try to make a call the phone shows a message thet says: SOME OF THE CONDITIONAL CALL FORWARDINGS ARE ACTIVE, and then it disapears.
  • CLJe Apr 04, 2008
    My screen no longer responds to touch.
  • Anonymous Jul 28, 2008
    i have a similar problem.. and it isnt covered under waranty
  • samadhan123 Sep 08, 2008
    hi my side key is damaged is there any other option to lock keypad??
  • Anonymous Nov 17, 2008
    I m having a motorocker E6 phone,
    the phone is having a side key to lock the screen function
    I had lock the key and now the key is damaged ,i was not able to
    operate the phone & so i just removed the battery so that i may restart
    the phone but now when i try to restart it shows a lock key symbol on
    its screen
    please help me to solve the problem
  • bhgf Dec 04, 2008
    hi my phone's side key lock has been damaged ,can u suggest me a solution
  • gopichand Dec 11, 2008
    its screen
  • Anonymous Dec 19, 2008
    my cell is in locked position and slider is not working.can any body
    suggest the service center near electronic city in bangalore
  • Anonymous Mar 30, 2009
    i have the same problem...i dont want 2 spend money...my phone is not under warranty any more..
    should i try to open it???
    too scared to do that.
  • 3 Answers
If yuor waranty is over, then you can just open the phone and remove the plastic slider. Then close the phone and use the stylus to operate the exposed key lock switch. This is the simplest way, i found. The plastic slider is very delicate and is very likey to break if you slide it very hard or after a few thousand times of lock/unlock operations. This is something Motorola should have thought about before designing it in. Like Nokia or HTC, they could just have put the screen lock control in the power switch/ phone on-hook switch itself.
Posted on Jan 13, 2009
Hi
i had the same problem of the side key lock
by this process u willnot be able to lock the phone aagain untill u repalce the side key
just by taking a pin slowly and soft handed slightly form top side of the key eenter the pin and remove the key then u will see the switch under it slide it up and ur mobile is in use again and press fit the key covering. u can use the phone without locking as I do
try switching it off & on see it worksif not repeat and dont lock
Posted on Mar 20, 2009
I too had the same problem!
    I just gave it to the service centre..And they fixed it...
My phone was under warranty and so they fixed it for free...
Posted on Dec 19, 2008
  • 97 Answers
Hi its a bit long process, but you can do it easily.
first you go to this webpage:
www.motorolafans.com
There in E6 section u either download qei lock or ilock software and use it as phone lock software. But remember that, your battery will drain out more quickly to lock phone with these softwares,
Thanks
Posted on Sep 08, 2008
Hi guys,
even i faced teh same problem..i went to service center and they unlock it for free in just 5 mins. but u cant lock the mobile again. for this u have to buy new slider costing around 250..better not to lock..
2 Suggested Answers
SOURCE:
  • 30 Answers
SOURCE: side key to lock is damaged of motorocker E6 phone
Dude just remove your side key away from your phone u vl find a small up & down key in side slot of side key take your stick & put it down to unlock use ur stick to lock or unlock ur phone..
Posted on Jan 27, 2010
I need to get into my LG ZTE T84 cell phone and I forgot the pattern. Is there an easy way to get past it without damaging data
From the LG website:
If you forget your lock sequence and backup PIN, you will have to perform a hard reset to gain access to your phone.
WARNING! Performing a hard reset deletes all of your user data, which includes pictures, videos, and music saved to your internal memory. Please make sure to back up your information prior to performing a hard reset.
  1. Turn the phone off.
  2. Press and hold the following keys at the same time: Volume Down Key + Power/Lock Key on the back of the phone.
  3. Release the Power/Lock Key only when the LG logo is displayed, then immediately press and hold the Power/Lock Key again.
  4. Release all keys when the Factory hard reset screen is displayed.
  5. Press the Power/Lock Key to continue or either of the Volume Keys to cancel.
  6. Press the Power/Lock Key once more to confirm or either of the Volume Keys to cancel
Oct 29, 2017 | LG Cell Phones
Steering wheel won't turn,its stuck and the key will not turn and engine can not be started
id say the 1st and the last symptom is caused by the middle symptom , to figure out whats wrong with that
1) do you have the correct key for that truck, folks that have more than one of these can mix up the keys for them , even repair shops can do it as well
(2) key damaged ??? keys get damaged all the time
(3) lock damaged ??? locks can become broken inside especially if one sticks the wrong item in there somehow
Aug 13, 2015 | 2010 Mercedes-Benz Sprinter
Door locks unlocks
Sounds like the main wiring loom into the door has been damaged.
Check near the hinges, where the door swings, to see if any damaged wires. Does the door lock and unlock from the drivers side switch?
Jan 04, 2014 | Toyota Cars & Trucks
I have a Samsun SGH-t219 cell phone. The send key is not working. Is it possible for this key to become locked accidently
Hello, The send key can not lock itself on accident. You may have liquid damage on that key. You can contact wireless image 303.482.1288 they maybe able to assist you on repairs.
Oct 23, 2010 | Samsung SGH-t219 Cellular Phone
Side key to lock is damaged of motorocker E6 phone
Sep 24, 2009 | Motorola Mobility MOTOROKR E6
My side lock is broken can it be rectified
i have a motorola roker E6 molibe phone .in this phone side lock key is broken by when i used key lock. now this time my phone is lock .what can i do . what is cost of repair my phone
Jul 15, 2009 | Motorola Mobility ROKR E6 Smartphone
Key will not unlock door
the lock on the driver side could be damaged or some on might have used a jimmy to open that door before how evr you have to open the pannel and remove the lock cylinder part and make sure that the key is working or yo must change the tumbler s in the lock to fit your key (lock smith)
Nov 19, 2008 | 2002 GMC Envoy
V3 razor screen is locked
describe ur problem briefly for help!!!!
May 16, 2008 | Motorola Mobility RAZR V3
Motorola Mobility MOTOROKR E6 Logo
676 people viewed this question
Top Motorola Mobility Computers & Internet Experts
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
JessicaChane2345
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
