Regulator - Power Windows - Front Door
CAUTION
To avoid damaging the trim panel, do not pull directly outward to
carry out this step.
CAUTION
Make sure the holes in the glass bracket do not become enlarged
during the rivet removal process. If the holes become enlarged, the new
rivets may become loose, resulting in clicking noise concern.
NOTE
Some vehicles may use rivets to attach the window glass to the
window regulator assembly. Use a 4.5 mm (0.1772 in) drill bit to drill
out the glass-to-regulator rivets.
Fig. Exploded view of the front door and power window
components-2005 Explorer and Mountaineer
To install:
To install:
how do you replace the regulator for the power - 4945f24.jpgrc="/uploads/images/4945f24.jpg" alt="4945f24.jpg" class="h_mi" />
Fig. Remove the equalizer bracket nuts-2005 Explorer Sport-Trac
Fig. Remove the front door window regulator motor retaining bolts
and then remove the motor-2005 Explorer Sport-Trac
Hope this help (remember rated and comment this).
SOURCE: 2003 explorer front passenger window regulator/motor replcement
You will first need to remove the door panel on the inside. Then you will need to remove the window glass from the track it rests in. Then you need to undo all the screws that attach the regulator inside the door. At the top of the door where the glass slides up and down remove the inner and outer window track guides. Then very carefully maneuver the regulator up and out the top of the door. Reverse the procedure to replace. It sounds easy, but you need to almost be double jointed to do this. So, have great patience while doing this task. Good luck.
SOURCE: 2002 ford explorer front wheel bearing assembly
remove hub ,take retaining circlip out and knock it out with a big big hammer supporting it on an old wheel rim and a tree trunk.this job is easy to do but unless you have the right tools entrust it to a garage who will have a nice press .
SOURCE: replace rear wheel bearing 2002 ford explorer 4x4
you must remove brakes, then remove axle nut, then remove upper control arm and finally tie rod stabilizer, remove axle from car then bearing can be accessed. this is a difficult job that requires special tools so be careful
SOURCE: I have a 2002 ford explorer that the passenger
I have the identical problem. I am suspect of the drivers side master switch or the wiring harness but not sure any help would be appreciated.
SOURCE: 2002 explorer power window fuse where
In the battery Junction Box check fuse # 6-60AMP will feed Central Junction Box (under driver side), the inline circuit breaker #47-30AMP, through the
Accessory Delay Relay, powered by fuse #17-15AMP to the Window Control
Circuit. Check the fuses, and for 12v at the points. Then check for 12v
at the driver side door switch pannel.
Also uou should check the plug into the main window button console in your
drivers door. The little piece of plastic around the door handle pops
out when pushed towards the front of the vehicle. This gives you access
to the buttons and harnesses.
Good luck (remember rated this help).
Testimonial: "good but windows only opens when drivers door open"
http://technoanswers.blogspot.com/2012/01/power-windows-will-not-go-up-and-relay.html
Electric Window Motor REMOVAL and INSTALLATION on ford vehicles?
http://schematicsdiagram.blogspot.com/2011/06/electric-window-motor-removal-and.html
Driver side power window wont go up on ford expedition?
http://howtobyme.blogspot.com/2011/10/driver-side-power-window-wont-go-up-on.html
How to replace window motor and regulator on jaguar S-Type?
http://howtobyme.blogspot.com/2011/09/how-to-replace-window-motor-and.html
How to remove window motor and regulator on Volkswagen Car?
http://howtobyme.blogspot.com/2011/09/how-to-remove-window-motor-and.html
power locks, power window and power mirror on the passenger side not working on
Ford Windstar
http://howtobyme.blogspot.com/2011/09/power-locks-power-window-and-power.html
All power windows not working on 2003 Cadillac CTS?
http://howtobyme.blogspot.com/2011/09/all-power-windows-not-working-on-2003.html
How to remove the door panel to install a new window regulator on Cadillac
Deville?
http://howtobyme.blogspot.com/2011/08/how-to-remove-door-panel-to-install-new.html
--------------How
to Remove Electric Window Motor on Acura Integra?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-electric-window-motor-on.html
How to replace power window motor in car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-power-window-motor-in.html
HOW TO REPLACE A POWER WINDOW SWITCH
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-power-window-switch.html
How to Replace a Window Motor
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-motor.html
HOW TO REPLACE A WINDOW REGULATOR WITH MOTOR
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-window-regulator-with.html
HOW TO REPLACE WINDOW RUN CHANNEL SEALS
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-run-channel-seals.html
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-window-regulator.html
How to replace power window regulator for 2006 Dodge Dakot
How to remove passenger side power window motor on Dodge Grand Caravan?
http://schematicsdiagram.blogspot.com/2011/09/how-to-remove-passenger-side-power.html
How to replace automatic window motor unit for the front passenger side on 2001
jeep grand cherokee Laredo ?
http://schematicsdiagram.blogspot.com/2011/09/how-to-replace-automatic-window-motor.html
how to replace passenger side power
window motor on 2001 Dodge van
All power windows not working on mercury sable?
http://technoanswers.blogspot.com/2011/09/all-power-windows-not-working-on.html
How to replace electric window regulator for mitsubishi 380 ?
http://technoanswers.blogspot.com/2011/09/how-to-replace-electric-window_05.html
how to remove window motor on driver side door panel on 1994 Oldsmobile Cutlass
Ciera
http://technoanswers.blogspot.com/2011/08/how-to-remove-window-motor-on-driver.html
driver side window problem on Mercury Sable
http://technoanswers.blogspot.com/2011/06/driver-side-window-problem-on-mercury.html
How to remove door panel, door window motor and regulator on 1991 cavalier?
http://technoanswers.blogspot.com/2011/05/how-to-remove-door-panel-door-window.html
how to replace the power window switch on 2005 BMW 325i?
http://technoanswers.blogspot.com/2011/03/how-to-replace-power-window-switch-on.html
How to replace window switch on bmw?
http://technoanswers.blogspot.com/2011/03/how-to-replace-window-switch-on-bmw.html
ford explorer window motor, regulator and door panel removal?
http://technoanswers.blogspot.com/2011/02/ford-explorer-window-motor-regulator.html
How to Replace a Window Switch on a 2002 Ford Explorer ?
http://technoanswers.blogspot.com/2011/02/how-to-replace-window-switch-on-2002.html
Ford F-150 Power Windows Not Working?
http://schematicsdiagram.blogspot.com/2011/12/ford-f-150-power-windows-not-working.html
Power windows works intermittently?
http://schematicsdiagram.blogspot.com/2011/12/power-windows-works-intermittently.html
Pontiac grand am power window not
working?
http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html
http://technoanswers.blogspot.com/2012/01/auto-open-close-feature-not-working-for.html
http://repairhelpcenter.blogspot.com/2012/01/lexus-es300-power-window-out-of-time.html
http://technoanswers.blogspot.com/2012/01/rear-power-windows-not-working-on-ford.html
http://technoanswers.blogspot.com/2012/01/all-power-windows-not-working-on-ford.html
http://technoanswers.blogspot.in/2012/02/2003-chevy-impala-power-windows-not.html
http://repairhelpcenter.blogspot.in/2012/02/diagnosis-testing-power-windows.html
