Question about KitchenAid KAWS750L Top Load Washer
Washing michine will not do anything
My washing machine will not fill will not spin agitate or anything else.looked at the three little plastic peices in between the motor and trans and they seem to be ok does anyone know what this could be.
    Novelist:
  • 131 Answers
If it won't do anything, check for power at the wall. Plug in something you know works.
If you have a top load washer with mechanical controls, and there is power at the wall, you need a timer.
Posted on Mar 12, 2008
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
Washer will not agitate or spin - still fills and drains
check the peice underneath the motor it is a plastic peice. and then check the dog ears inside the agitator. thats what i had to replace and it cost about 30 bucks. and took about 30 minutes.
Sep 19, 2011 | Whirlpool LTE5243D Top Load Stacked...
Wahing machine will not wash
the entire agitator is not moving during the wash??? or just the top section that looks like a big plastic corkscrew???
or is the unit actually just filling with water, making the motor running noises and going thru the motions of running a cycle yet not actually moving anything within the unit, then draining out as normal??
if just the top section of the agitator is free spinning instead of ratcheting as normal you'll need to replace the agitator dogs if present.
if however the units just filling and draining of water with no inner movement then more likely the drive coupling is bad and needs replacement..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
My washer fills with water then stops, fills a little more then stops again. It never starts agitating or spinning to wash the clothes. Just fills with water.
The probable reasons for your washer not to agitate or spin could be any one of the reasons mentioned bellow:
If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Many washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Thank you for contacting Fixya.com
Aug 09, 2009 | Kenmore Washing Machines
Kenmore Series 70 top load barely agitates....
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Three places to look.
1. Assuming that this washer has a two piece agitator, I'd check the "agitator dogs" on the top section.
2. It's possible that the splines on the agitator have worn over time.
See the following description of how to remove the agitator.
Look inside the agitator at the splines.
3. It's also possible that the splines on the agitator shaft have worn.
With the agitator off, check the condition of the splines. If they are worn, the options are to replace the agitator shaft (disassembling the transmission) or replacing the transmission itself.
May 06, 2009 | Kenmore 15864/15862 Top Load Washer
Washing machine, kitchenaid, found brass looking pin w/hole in en
No,there are two such pins in the machine for shipping purposes only when it is shipped out,they drop out into little plastic cups under the machine after delivery,
 If it doesn't spin or agitate check the coupler located between the motor and gear box consists of three pieces two are plastic one on the motor and one on the gear box the other connects the two in the center it is rubber.
 If it spins but doesn't agitate,most likely a bad gear case.
Mar 08, 2009 | KitchenAid KAWS850LE Top Load Washer
Washing machine will not spin or agitate.
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Ge wvsr1060a2ww washer does not spin or agitate
first look to see if this is a belt drive. If not look for a coupler(round black rubber piece with three holes, three plastic fingers from both sides going in it) from the motor to the gearcase. The motor sit between the pump and gearcase, it will pump out, but not spin.
Nov 08, 2008 | GE WVSR1060A Top Load Washer
Washing machine
your transmission is fried
Oct 15, 2008 | Washing Machines
KitchenAid KAWS750L Top Load Washer Logo
65 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Eric Taylor
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
