Question about Kenmore 63942 Dryer
Press button dryer clicks but doesn't start
The dryer was working it dried a load of clothes. My husband smelled an electrical burning smell (the dryer was off.) When I reset the timer the dryer clicks like it's trying to start but the machine doesn't start. Thanks in advance for any advice, a[email protected]
  • Andrea0516 Mar 12, 2008
    No, it's been a few days. I was wondering if (a) the motor probably burnt out - the machine is 9 years old and if so (b) if it is something I can repair myself (no electrical/mechanical knowledge.)
    Do you think it is the motor or R2, C2, C25, DZ1-DZ7 (I don't know what those are) or is this something I need to call in the repair man on?
  • 2,337 Answers
You will find plenty of information on how to DIY HERE
NOTE: Beware when working on this appliance, MAKE SURE you unplug it from the power outlet before start working on it.
Posted on Mar 12, 2008
  • Jaime Hernandez Mar 12, 2008
    There may be a number of things to be check before concluding that the motor is burnt.
    A continuity test should be done on the motor, just to make sure the motor is good. Even if the motor is tested good, you will need to see if it rotates freely and properly.
    The LINK outlines all the testing need to know where the problem is.
    If you feel confident that you can do it. I would suggest to take a lot of time to read and understand what you will be doing.
    Calling a technician is really up to you base on the amount of electrical testing that is needed to perform this task.
    The mechanical aspect of the machine, you can check it yourself, by inspecting for a broken belt, jammed motor or burnt components on the control board. The rest is all electrical testing.
    Good Luck.
    Guru:
  • 1,894 Answers
Then it means motor is got jammed..
  • 1 more comment
  • dewan nafees ahmed Mar 12, 2008
    the motor would try to start every time and it wil not..
    it must have stopped due to over running of motor
    just leave it for few hours and try it again
    The burnt parts on the control board are all in the DC power
    supply circuit.
    I believe the board can be repaired with
    just a few components (R2, C2, C25, DZ1-DZ7).
SOURCE:
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
Hi. My Neptune dryer was not sounding as I remembered it. A higher pitch than usual while it was drying clothes. Then I noticed it was reluctant to start when pushing the "start" button, with...
burning smell is because the drum is not rolling and the motor is trying to turn, hopefully it did not damage the motor: more then likely it the drum rollers/glides, might want to check the idler arm here is a website that will help. depending on fast you need your dryer a good and cheap place to buy parts is on eBay, of course they can be purchased locally, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jan 10, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
A STRANGE SMELL WHEN DRYING..
sounds like brushes they can cause a burning smell......as for clothes smell after drying the fan in the heater could be dirty but generally that would mean the heater will not work
Mar 18, 2009 | Hotpoint Aquarius WD63 Front Load...
GE Dryer smells like its burning
the burning smell may be caused by a belt some have a look at the belt
Mar 07, 2009 | GE Dryers
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
Burning smell after hitting the reset button
the lint may have moved into the motor/ or other areas, clean the unit again and have another inspection, checking for burn't wire etc.
Jan 25, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Clothes smell like gas
STOP USING THE DRYER AND CALL A QUALIFIED SERVICE PERSON TO TEST ALL GAS LINE CONNECTIONS WITHIN THE UNIT!
A gas leak can cause a fire in your home. Although, we have always used a gas dryer, and the clothes do have a fresher smell to them than an electric dryer. Any gas which may be in the area would be consumed when the gas flame was burning as normally the pilot remains lit throughout the drying cycle.
Jan 24, 2009 | Kenmore 43142 Front Load Washer
Kenmore 63942 Dryer Logo
138 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
