Question about Mitsumi (CRMC-FX4821T) (crmcfx4821t) Internal 48x CD-ROM Drive
NONWORKING CD ROM
I have a mitsumi CD ROM (Model # FX4821T). Something is wrong with it & I don't know how to fix it. The error message reads: "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)". How can I repair the driver?
  • Anonymous May 14, 2008
    File may be corrupted or missing Error Code 39
    President:
  • 1,257 Answers
Follow this article to fix the issue:
http://support.microsoft.com/kb/314060
Posted on Apr 23, 2009
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 18, 2008
  • 871 Answers
Try to look for a firmware update for your cdrom and try to reload the drivers for that. your cdrom may just need an update from the manufacturer.
Posted on Mar 12, 2008
Disk read error on Samsung NP-R519 laptop
Check CD-ROM; whether it has scratched CD than difficult to read by CD drive.
Dec 10, 2013 | Video Game Consoles & Games
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Apr 17, 2013 | Microsoft Windows 7 Home Premium Operating...
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Mitsumi cd-rom fx4821t wont work
have you installed any software for compiling the data and writing it on the disc....
try to use nero and tell if it shows any error
Aug 31, 2008 | Mitsumi (CRMC-FX4821T) (crmcfx4821t)...
CD ROM drive not seen in "device manager"
i think you are going to have to boot into bios and where it shows the boot configuration look to see if there is a cdrom there if not change it so the computer will have the cd rom in there along with the harddrive and the a drive then save it and exit and reboot then the cd rom should be back into the device manager and also under my computer
Aug 17, 2008 | Samsung TS-H492 (TSH492AWRBH)...
How to Install mitsumi dvd r rw cd r rw in desktop case
check both documentation packages for dvd and m/b...that will tell you, no doubt....without the m/b part number or maker, we can't do much for you here
Apr 23, 2008 | Computers & Internet
The CD-ROM, Run but too slow.
CD ROM Drives
This site could help ya in need of the drivers .
Hope this fixes the problems you are having .
This could help ya in the way of doing this your self at this site.
Have a great evening.
Dec 02, 2007 | Computers & Internet
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
Error Message on CD Rom - will not operate
Your CD ROM needs to be cleaned from inside may be it can't read CD because of dust on lens
Nov 06, 2007 | Computers & Internet
Mitsumi (CRMC-FX4821T) (crmcfx4821t) Internal 48x CD-ROM Drive Logo
173 people viewed this question
Top Mitsumi Computers & Internet Experts
David Payne
David Payne
Are you a Mitsumi Computer and Internet Expert? Answer questions, earn points and help others
