Wurlitzer 2600 The record is selected but does not play from the start of the song but plays a couple of seconds into the record Does any genius out there have any solution Many thanks Bob
Think it's only a small adjustment on the tone arm. See if you can find a manual for it on Ebay. It's a must..I think Victory Glass has them or maybe Always Jukin Both dot coms
Dave
Posted on Apr 08, 2008
SOURCE:
Tip
How to Create a Genius Mix in iTunes
<p><span>One fun thing to do in iTunes is to use the Genius tool to create a Genius Mix. Genius Mixes are playlists created by selecting a song, and then allowing the iTunes software to choose songs that sound like it, and that would go together well in a playlist. iTunes has done you the liberty of already making a couple genre mixes for you. However, if you want iTunes to create a new Genius Mix, there are a few simple steps you need to take.</span><br /> <p><span><br /></span><br /> <p><span><span>1.<span> </span></span></span><span>Go to your music library and choose what song you would like iTunes to base the Genius Mix off of. </span><br /> <p><span><span>2.<span> </span></span></span><span>Right click the song and select "Start Genius". iTunes automatically selects 25 songs that sound great when played with each other and puts them in a playlist. </span><br /> <p><span><span>3.<span> </span></span></span><span>From here, you can drag your Genius Mix into a new playlist, which can modified as you wish, and played on your iPod</span><br />
on May 27, 2011 | Apple iTunes
MY TURNTABLE START PLAYING ON THE SECOND SONG OF THE 33" VINYL, WHAT IS THE PROBLEM
Do you have a switch to select the size of the record as well? We had a record player that could play 7" singles at 33rpm (floppy vinyls given away by Sunday papers). We had to select 33rpm and also 7" on a separate lever for this to work.
May 23, 2014 | Marantz Audio Players & Recorders
I have a Wurlitzer 2600. There are 2 issues with it. First, the machine was playing when I bought it. After an evening of playing the, what I call the plunger, inside the spinning drum moves into the...
W2600 and similar boxes have issues grabbing any record that has an uneven hole. The selection process can go through the motions but if it doesn't pop up a 'pin' on the selector drum then nothing else will happen. Check for a pattern, like all 1 or all C fail and it will indicate the actual problem.
Dec 01, 2013 | Audio Players & Recorders
Only plays one song at a time; not through entire cd
This is not a problem, the machine is supposed to play only one song at a time.....If you want to play the entire CD at a time, you must first program the machine for "Album Play" and then select the disc number followed by "00". Refer to your manual for instructions on programming album play. PS I sell manuals, [email protected]
Feb 05, 2011 | Wurlitzer Jukebox 1015 One More Time...
I have a wurlitzer juke box 1965 and it's clicked off free play, it will only now play one record at a time by keeping pressing the reset button.
The free play switch is only supposed to allow one selection on most Wurlitzers. If you email me the model number, I may be able to advise how to put it on continuous free play. My email address is [email protected].
Aug 07, 2010 | Wurlitzer Jukebox 1015 One More Time...
Changer will pick up CD and spin for about three seconds stop, set still for about four seconds. CD will not spin again reject CD back into the rack. the above will happen again but during the four second...
This sounds like an issue with either your CD player, CD control board, or Selection and Credit Computer. I can help you troubleshoot further over the phone (and repair/replace whatever is necessary). My name is Rod and I can be reached at [email protected]. Please email me and I'll email you my telephone number.
Jun 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
2900 Keeps playing records
THE WURLITZER JUKEBOX WILL CONTINUE TO PLAY SONGS AS LONG AS ONE OR MORE, SELECTING PINS (THERE ARE 200 IN THE 2900 ONE FOR EACH SONG. THE PINS ARE IN LOWER SECTION OF THE CASE. BETWEEN THE SPEAKERS , AND LOWER DOOR.)
REMOVE LOWER BACK DOOR. WATCH THE ARM THAT STOPS ON THE NEXT RECORD, BECAUSE THE PIN IS UP. AFTER STOPPING ON THE PIN, THE ARM PUSHES THE PIN DOWN. THAT IS THE NORMAL OPERATION. IF THE PIN, IS NOT PUSHED DOWN, IT WILL PLAY THAT OR ANY OTHER SONG THAT HAS A PIN IS RAISED UP. THE PINS ARE THE MECHANICAL MEMORY FOR THAT JUKEBOX.
TURN OFF POWER, ==PUSH ALL PINS DOWN== THE SONGS WILL STOP PLAYING. THEN MAKE A SONG SELECTION. THE ONE PIN WILL POP UP THE MACHINE SHOULD PLAY THAT SONG.
WATCH THE ARM THAT STOPPED TO PLAY THE SONG, PUSH THE PIN DOWN. THAT IS THE SEQUENCE OF THE 2900 MACHINE,
WHAT CAN GO WRONG IS AS FOLLOWS. ==THE ARM DOES NOT PUSH PIN DOWN== THE ARM MISSES PIN== THE ARM NEED OIL, IT IS NOT LUBRICATED.==.
Mar 08, 2009 | Wurlitzer Jukebox CD Player
Seeburg Stereo Phonograph Model ESL100 Q-65-H5
End of record switch out of adjustment or bad? Disconnected?
Mar 05, 2009 | Wurlitzer Jukebox 1015 One More Time...
126 people viewed this question
Ekse
 Grubhead
Grubhead
