Question about Cuisinart DFP-14BC Custom Food Processor
I cannot get my processor to start
I switched my blade for the first time to shredding and I have everything locked and cannot get it to turn on?
  • Anonymous Jan 04, 2009
    i switched from a 2.6 to a 2.8 and it wont read new processor any sugg
    Scholar:
  • 79 Answers
Food processors are notorious for having safety interlocks. If everything - and I mean everything - isn't attached in the correct sequence and clicked into place, one of the safety switches may not be engaged.
You can test it by switching back to the setup you used before to see if it will still operate. If so, then CAREFULLY review all the steps needed to use the new setup.
Posted on Mar 15, 2008
MACHINE WON'T TURN ON AFTER BEING USED
I am guessing that something is not seated properly. Make sure the bowl clicks when turned...drops the pin in. Make sure the top is ("clicked in") locked. If you poured something out of the bowl and went to re-use it, make sure the blade is seated properly; make sure there is no food caught under the blade hindering the blade to be seated. Everything must be locked in correctly to operate safely.
Mar 25, 2014 | Cuisinart DLC-10S Pro Classic Food...
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
I want to shredd zucchini to freeze for later use in zucchini bread. Lost manual. What blade should I use
To shred it into thin strips, use the blade with a series of holes in it. To slice, use the blade with a knife blade in it.
Sep 11, 2009 | KitchenAid KFP760 12 Cups Food Processor
Replacement slicing and shredding blade
Same thing happened to me. Did you ever find one?
Apr 04, 2009 | GE Food Processor
Broken part for Technique food processor
PLease check ebay seller churkey123 if these are the same processors. WIll send replacment parts for blade holder for postage!
Dec 09, 2008 | Food Processors
Blade
Try adjusting the speed up or add the onions a little at a time. Another sugestion would be to use the blade holder and run the onions thru that way ( Shredding them) prior to doing the rest of the reciept with the quad blade.
Nov 21, 2007 | Bravetti Platinum Pro Quad-Blade Food...
Cuisinart DFP-14BC Custom Food Processor Logo
745 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
