Question about Motorola Mobility V365 Cellular Phone
Phone will not charge
V365 will not hold a charge. If plugged in, it will stay on but the battery will not charge. If not plugged in it will turn off after a few minutes. Phone was a gift. Also, the charger is not a manufact. charger but a universal one; don't know if it makes a difference. I don't know if it's the phone or battery or charger and would like some help to try and find out before buying all three.
I have the same issue. Says insert SiM. The phone is new and undamaged. Rather irritating.
All parts original, no odd usage. Just won't hold a charge, and now the SIM card problem.
Posted on Oct 14, 2008
    Problem Solver:
  • 9 Answers
Try once using original charger and just check that your charge pin is connected well with the phone
Posted on Jul 25, 2008
Hi Mine is a iPhone 3GS 16gb it will not charge nor turn on when I hold down the on off button nothing happens but when I plug in the charger and hold the on off button it shows the charging sign which...
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 31, 2012 | Computers & Internet
My Samsung Comeback will not charge. When I plug it in and it's turned off, the bars go up, as if it's charging. But when I charge it for a long period of time ( longer than usual for it to be fully...
Hey! My Sister has the same problem. T-Mobile said that it is the battery. There was a defect with some phone batteries. You can buy the samsung battery from T-Mobile for like 48$ of go to cellphoneshop.net to get it cheaper. works great and is cheaper to replace than 48$ samsung battery!!
Aug 20, 2010 | Samsung Comeback Cell Phone
Motorola v365 won't charge and won't stay with wall power
The reason your phone wont charge might be because there is a problem with the battery, the charger or the charging port.
To test it if it is the battery,
Insert the battery into another phone and try to charge it for a while,
if it does not work, then it is the battery.
All you have to do is to change the battery.
To test it if it is the charger,
Plug the charger to a power supply,
Connect the charger to another phone, to see if it works.
If it does not work, then it is the charger that needs replacement.
To test if it is the charging port,
Insert a new battery, and plug it to a new charger.
If it does not charge, then it is the charging port.
Replace the charging port and it will be okay.
To replace the charging port;
  1. After removing your back cover and battery, remove the four torx 6 screws you see. (When reassembling, the gold screws go at the bottom and the silver screws go back at the top),
  2. With the four screws removed you can now remove the battery compartment,
  3. With the battery slot removed you have access to one of the ribbons which connects the screen to the main body of the phone. Unclip this (it fits like a plug and socket).
  4. You'll now have the phone in two parts,
  5. Take to the lower part and disconnect the charging port and replace it with a new one,
  6. Reverse the whole procedure for reassembly
Take care
Jun 19, 2010 | Motorola Mobility V365 Cellular Phone
Inserted boost mobile sim card into AT&T Motorola V365
it can not work at all, boost mobile uses IDEN which is different from GSM. even if you unlocked the phone it won't work , sorry
Apr 01, 2009 | Motorola Mobility V365 Cellular Phone
Motorola V365 - turns on then off immediatly
I have this phone. There is nothing you can do about this problem. The only thing you can do is hope the phone is still under warranty or you have insurance to replace it. I was surfing on AT&T website and found this information for problem cell phones. I am quite sure you can surf your carrier website and find the same information. Look for something like- how do I replace my broken phone or warranty information. Hope this info helps!!!! Just click on the link below.
For AT&T (Cingular) - the warranty is valid from 31- 365 day from date of purchase.(less than 30 days return to place of purchase) The warranty comes with the phone for free. I missed the warranty window by 10 days ……………What luck.
http://www.wireless.att.com/answer-center/main.jsp?t=solutionTab&ft=&ps=solutionPanels&locale=en_US&_dyncharset=UTF-8&solutionId=KB91429
Dec 26, 2007 | Motorola Mobility V365 Cellular Phone
Wont Turn on
while charging your phone try to switch on your phone .or just try to switch on and switch off your phone 3-4 times continiously even if dosent work take it to the authorised service center
Lg chocolate
hold the end key to turn on.. if nothing happens plug it in.. i had to charge mine for abour 2 1/2 hours before it would work
Dec 25, 2007 | LG KG800 Cellular Phone
Motorola Mobility V365 Cellular Phone Logo
132 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
