Question about Konica Minolta DiMAGE A200 Digital Camera
I have a Konica Minolta Dimage A200. The memory
I have a Konica Minolta Dimage A200. The memory card was inserted wrong and it bent the pins internally. Can this be fixed? Estimated cost?
    Problem Solver:
  • 7 Answers
If the pins aren't bent to bad, there are a chance that you could take the camera to a repairshop and ask them to either replace or bend back those pins that has been bent. A bit of warning i can be expensive due to the fact there are great deal of screws needed to be removed and several cables needs to be extracted from the cpu board, tough the expansionslot connector is located beneath the cpu board. It took me about 30minutes to disassemble the camera entirely so it's possible to repair the flash card pin connector. And about the same time to reassemble the camera.
Posted on Jan 25, 2013
  • 30 Answers
I can be fixed, but will be expensive. Get a local quote.
Posted on Jul 02, 2010
SOURCE:
My camera does not recognizes the memory card can not take any photos
The card could be locked, there is a little sliding switch on the side of the card. Is the card formatted? Usually on a new card you have to put it into the camera and go through the menus to the format card menu.
Dec 27, 2010 | Konica Minolta DiMAGE A200 Digital Camera
My Konica Minolta Dimage A200 do no recognize the memory cards. Can anybody help e to solve this problem?
Format the cards in the camera. Make sure you download any pictures that might be on the cards first. Use a card reader if necessary.
Oct 12, 2009 | Konica Minolta DiMAGE A200 Digital Camera
Can't format a memory card for my minolta damage
Some brands cannot be used by some cameras. You should stick with the big brand names like Sandisk.
Sep 28, 2009 | Konica Minolta DiMAGE A200 Digital Camera
Suitable compact disk memory card for dimage a200
I have the same camera. It will use up to a 4GB card as standard and up to 8GB with the correct firmware.
Check the following web address for further information: -
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-a/dimage-a200/software_drivers/firmware/installation_guide.html
I hope you find that my answer has helped, if so please return the favour by rating my answer.
Jul 21, 2009 | Konica Minolta DiMAGE A200 Digital Camera
My Minolta DiMage A1 displays "no card" when memory card is inserted. It's not a new card...it's the same 128mb card I've used since I bought it. Any suggestions?!
If you're lucky, the CF card is faulty. It's going to be a very old card now if it's the original one supplied/bought with your A1. You've never upgraded to a larger card in all this time so it suggests you've never needed to. 128 and 256mb cards are virtually worthless now, so I'd be amazed if you couldn't get one for free via Yahoo FreeCycle. You can also try reformatting your card in a card reader/writer, but A1's and A2's often won't recognise a card formatted in this way and it can render them permanently unreadable by all A1/A2/A200 cameras.
If you're unlucky, then you've bent or broken one or more of the pins inside the card slot which connect to your card when you insert it. To check, get a bright torch and look down inside the card slot. Any bent pins will be self evident as there should be a neat double row of pins and missing pins will show up as gaps.
If you have bent pins then you've nothing to lose by trying to carefully straighten them, if you can't or if the pins are broken, then your camera is effectively irrepairable. Scrap A1's and A2's can both provide the part, but retreiving them from the donor camera is really difficult and so far I've never managed to refit one successfully and I've done a few now. A pro repair is simply not cost effective, especially when a perfectly good used A1 goes for around £40-£50 and the better A2's go for around £80-£100. If you're in North America you can expect prices to be even lower.
Jun 24, 2009 | Konica Minolta DiMAGE A1 Digital Camera
Konica Minolta Dimage 7Hi - Faulty
It could (note I'm saying could, not is) be a bent flash card pin. If you get it, take a look inside the camera's CF card slot. If a bent pin is spotted, remove the batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. The jeweler's screwdrivers that you see at the dollar store will work fine. Another tool that I sometimes use is a stiff wire with a bent hook on the end to get very flattened pins started. Take your time and use as much patience as you can muster (take a breather in between if needed). Just keep nudging it upward/straighter a "tiny bit at a time". Whatever you do, don't try to unbend it with one push/nudge, you won't be able to do it.
It doesn't have to be perfect, just as close as you can get it. When it's the best that you can get it, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Now if you get it and there's NOT a bent pin in there (say it's a missing pin, a very different story) don't come back crying here! :-)
Jun 06, 2009 | Konica Minolta DiMAGE 7Hi Digital Camera
Camera doesn't acknowledge card when inserted into camera
Hi
Whats the capacity of your memory card? check for compatibility of card, since memory cards that have 4gb to 8gb are not compatible with some cameras. check as well from your cameras manufacturer if they have a firmware that will support such cards for your device/camera.
Hope this helps
May 10, 2009 | Konica Minolta DiMAGE A1 Digital Camera
How long does it take to boot the camera?
Approximately 2.2 seconds in recording mode. It depends on the type of memory card being used.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
What are the available ISO rating for the DiMAGE A200?
The DiMAGE A200 sensitivity can be set to Auto, ISO 50, 100, 200, 400, and 800. When Auto is selected, the camera automatically controls the sensitivity within the range of ISO 50-200.
Konica Minolta DiMAGE A200 Digital Camera Logo
279 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
