Question about Samsung CLP-510 Laser Printer
Black Streaks Everytime I print the pages are streaked with black lines. I have changed the black toner cartridge and vaccumed out the inside. The wide streaks still appear. Help!!!!
  • Anonymous Mar 27, 2014
    New toner added now have steaks on copies and prints
    Sergeant:
  • Samsung Expert
  • 406 Answers
The Black Lines are not due to to toner problem.
The Black lines ate same at the Page Location . If so the Problem may be with Drum Or Charging Unit Or fuser assembly. If the same problem continues Please take out and see the drum do not toch it . (Please Power off the Printer and disconnect all the cables. )
REgards
Rafique
Posted on Mar 12, 2008
SOURCE:
Black marks on pages when i print
Do the streaks get fainter as you print more pages?
It sounds to me like have toner on your rollers/fuser.
Print out 10 prints from the printer and see if it improves.
If you remove the fuser wiper cover from the top of the printer and look down you will see part of the fuser roller (DON'T TOUCH VERY HOT) and check if there is toner on it.
John
Nov 21, 2011 | Lexmark T520 Laser Printer
Printed pages have streaks vertically along edge
Sounds like the end seals in the cartridge are bad. Remove the cartridge and see if there is toner built un inside printer. Also look at the drum on the cartridge to see if it has black lines that line up with the pirnt defect you are seeing. Try a new toner cartridge and run about 50 pages through.
Apr 30, 2011 | Brother HL-4040CN Laser Printer
I am getting black streaks on the printout page. must i refill or replace a new catridge
Dirty print out is basically due to cartridge related issues. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is usually located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, black streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. In this case refilling would not help.
So, it is recommended that you replace the cartridge with a genuine one (not any replacement or refill).
Let me know if any further clarification is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 01, 2011 | Canon LASER SHOT LBP-2900 Printer
I have black streaks on my 1600n prints. I have tried cleaning the drum, however the streaks still exist.
Moreover, black streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Cartridge or get the PCR Roller changed by a professional.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 06, 2011 | Dell 1600n All-In-One Laser Printer
Our copies are streaky like the drum is not clean.... help! There is black streaks on the top of all of our copies on our canon imagerunner 3300.
A) Black Streaks, Shadows, And Ghosting
Adjust the printer's lightness/darkness setting to 2-3 different variables and see if problem disappears. Look at the fusing assembly - is the roller torn or does it have any black buildup? Use caution!!! It gets HOT!
Try another toner also.
Feb 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
My drum is at 40%. I have black vertical streaks
I was going crazy! Had a tech come in and look at the machine - needless to say he did NOTHING! A friend came over and was trying different things. It was that the "rack" that the toner cartridges sit in was not fully seated - once he pushed down a little and heard it "click" I had no more black streaks. AMAZING
Mar 30, 2009 | Brother MFC-9840CDW Laser Printer
CLP-500 vertical streaks & a horizontal line with blotches appearing randomly
I've refilled the toner cartridges a few times now and never had a problem with vertical streaks until recently. I refilled both the cyan and magenta and when I ran the test page I had dark vertical streaks on both sides. I fiddled around cleaning things, running cleaning paper through, changing reset resistors but to no avail so eventually decided to buy a replacement refurbished cyan cartridge since the streaks looked mainly blue and bingo... well almost now I just have very light magenta streaks. The issue is obvious when I compared the old and new cartridge, the replacement toner is a much duller cyan and is of the wrong consistency since once it's been in the printer everything gets covered in it which is why I think it causes the banding to occur. I'm just trying to work out now whether to try refilling the magenta again (v. messy) or just go for another refurbished cartridge (£34).
Jun 12, 2008 | Samsung CLP-500 Laser Printer
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Black streaks on printout page
It sounds like excess toner has built up in or around the imaging drum. I would *carefully* remove the toner and drum (can be messy) and use some canned air to clean the inside out. If you are still getting these streaks, it might be time to get a new drum (DR 400) as you are supposed to replace the drum every 6 to 8 times you change the toner cartridge.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Samsung CLP-510 Laser Printer Logo
1,038 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
