Question about Refrigerators
I have a new side by side Whirpool serial ED2JHAXT001 that has an ice jam in the ice cube maker. I have mislayed my manuel or accidently thrown it away. How can I break it up without damaging it or do I need a repair man. I also have been having things in the bottom drawer of fridge freeze and the setting that the delivery man set. I have turned the setting to 2 for the fridge but it is still just about freezing.
  • 552 Answers
You need to first of all defrost it by unplugging overnight.
Then run it again and if the ice builds up again, then you may have a problem with the defrost heater.
Let me know if this helps.
Posted on Mar 12, 2008
My ice maker is slow on making ice, perhaps in part it keeps clicking like it's stuck and trying to eject a jammed ice cube, but there is no jammed ice cube as in the past was randomly the case
First woul check the water filter then replace unit, most are fairly easy if you can
Get to water shutoff valve. Many units are fairly cheap $40 and up.
Dec 13, 2017 | Refrigerators
Ice maker ice jam
Not a whole lot you can do but to keep the frost down.
If you are able to move the items in the freezer to another freezer and let it sit overnight, all your problems will melt away....
Until a couple months later when it builds up
Make sure to double check your freezer is sealing correctly, bad gasket causes moisture to be sucked in.
Here are some basic ways to slow the buildup
How to Avoid Freezer Frost
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 10, 2016 | Samsung Refrigerators
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Ice cubes stick together
have same problem with industrial ice maker machine at my work because the setting is too cold to let the ice cubes separate.
Apr 15, 2014 | Refrigerators
Frigidaire side by side with ice maker .. ice maker jams and quits making ice
Hollow ice cubes are a result of lack of water to ice maker. This can be caused by lack of water pressure (clogged filter, bad water valve, obstructed fill tube, etc..) you will need to find the cause to correct this hollow ice cube issue. The ice maker should take on 5.5 oz of water when it cycles (2/3 cup). Mot of the time its a water supply issue and the line could be kinked behind the unit as it was rolled back into place.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dec 30, 2013 | Frigidaire FRS23H7CS Side by Side...
Ice maker will not make ice cubes...it dispenses water, but no cu
two common problems are the spring comes off the feeler arm or the ice cubes jam on the sweeper the plastic arm with fingers on the edge of the ice maker
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Cubes won't dump into the storage bin
In photo below you can see the heating element that comes on moments before the ice maker drops the ice. If not working then the icemaker will struggle to unload. You need to unplug the refrigerator and then unpluge the ice maker and remove it to test these parts. Test with a multi meter or ohm meter. Test the 2 connections next to the number #26. Hope this helps, Sea Breeze
May 21, 2009 | Whirlpool GS5SHAXN Side by Side...
ZIS480DRISS NO MAKING ICE CUBES
FINGERS THAT EJECT THE CUBES WAS JAMMED ON WHITE PLASTIC. REMOVED ICE MAKER THAWED CUBES IN THE TREY AND PRYED AWAY THE WHITE PLASTIC COVER. RE-INSTALLED
Jan 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker quit
i doubt you did damage switching it off. justmake sureits back on. lif tthe flap covering ice maker.Is there ice in it and not ejecting?perhaps an ice cube caught in ice maker tines preventing maker more
Feb 24, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
