Question about Toshiba TW56X81 56" Rear Projection Television
Wobbly lines on my Toshiba TW56X81
I saw your post and thought I'd check with you before I went to a local repair man. We got this tv from a friend who upgraded to a LCD Projector TV. This tv has "wobbly" lines across the whole screen (they appear to be vertical lines). It seems to lessen as the tv is on longer, but still always has some. If you have any ideas or direction, please email me at jamie.witten@wamu.net.
thank you,
Jamie
  • suez419 Dec 24, 2008
    wE HAVE WOBBLY LINES [VERTICAL] ON OUR 6 YEAR OLD tOSHIBA LATELY TOO. iT DOESN'T HAPPEN WHEN WE WATCH TV ON THE SATELLITE pvr BUT HAPPENS WHEN WE PLAY A dvd OR vhs tAPE. My email is suez@shaw.ca
    Problem Solver:
  • 9 Answers
This sounds like a input problem. The source of the signal may not be well matched to the expected input spec. To test, see if the "SETUP" menu items are clear. If so it is something to do with a cable, connector, or configuration of the source.
Posted on Feb 18, 2010
Electrocution when connecting TV
You have a major electrical fault. You need to get a TV repair man to check this out.
Do not turn this TV on as you maybe electrocuted.
May 15, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Toshiba 56hm195 tv picture freezes
Check to see if using HDMI input and if so try component input and also advise me if using box of some sort.
Mar 12, 2012 | Toshiba TW56X81 56" Rear Projection...
Toshiba TW56X81 power LED blinking ,tv won't turn on
Try unplugging and waiting about 2 min. Then retry. There is a self protection circuit which is what is stopping the unit from coming on, but it can be triggered by many things. [Units this old are famous for the capacitors (electrolyte dries out and then they blow), but that is just the most common problem. I would look the capacitors over and see if they give any indication of being "blown" (discoloring, etc.) and replace them if they do.
Oct 17, 2009 | Toshiba TW56X81 56" Rear Projection...
Toshiba tw56x81 plug it in and it makes a
you have freid the fuse inside it its a cheap and easy fix i have anserd 3 allready todsay on this problem it is very common and under £50 to fix
Sep 19, 2009 | Toshiba TW56X81 56" Rear Projection...
42" toshiba tv
Sorry but you are out of luck, the unit will need repair. It could come back to life in any moment but most often is related to this:
My previous post here
I have seen a faulty board work perfectly until the power is removed (intentionally or accidentally) an applied again or reset via the power button for 5 seconds. This will effectively disable the +12 VDC Power oscillator rendering the TV unusable.
good luck,
mrwindex
Jul 30, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Toshiba tw56x81 rear projection tv "protection fault"
Jan 04, 2009 | Toshiba TW56X81 56" Rear Projection...
Toshiba Satellite 1415-S173
Hi
DC jack replacement is easy however requires a bit care since its mounted on the mainboard. Desolder the old DC jack. Solder the new one firmly. Dont keep the soldering iron too long on the PCB as it will damage the lines and will deform the DC Jack. You can get DC jack very low cos from local repair stores or you can order from Toshiba parts depot (800-524-8338)
Please post your question if you need further assistance.
Good Luck
Feb 09, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Toshiba TW56X81 Convergence issues
I retired from the TV repair business because if you are not an authorized repair service center most manufacturers will not even talk to you. If you are electronically inclined you can repair this tv. your problem is a bad convergence ic. you need to be able to locate it and replace it. it probably has about 15 or 18 legs that need to be unsoldered and a new replacement re-installed
Sep 29, 2007 | Toshiba TW56X81 56" Rear Projection...
My TV will not come on but the power button blinks red!
Very interesting. I have a Toshiba 53 H71. Same issue. It occurred to me after a move.. No one has offered any help on it. Posted about a week ago. Guess no one knows anything about these TV's....
Sep 02, 2006 | Toshiba 50HX81 50" Rear Projection...
Toshiba TW56X81 56" Rear Projection Television Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
