Question about Largan Mega 2 Digital Camera
USB Link Error
When I connect my camera to download the pictures to my windows XP computer, I get the USB Link Error message. This problem happen before and I just reversed the usb cable and it worked fine until yesterday. The cable and the camera seem fine so I don't know what the problem could be.
I experienced the same problem, and tried connecting the usb into another usb input on my laptop and it worked.
Posted on Mar 27, 2008
6ya staff
SOURCE:
When I am connecting my Samaung Digital model S860 with PC having Windows Xp (Profectional) via USB cable, nothing is happening at PC screen. Also I don't have driver CD with my camera. Please sen
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 08, 2013 | Samsung S860 Digital Cameras. 8-megapixel...
Every time I connect my camera to my laptop (windows xp) it seems to be working to open the camera window, then an error message appears saying camera is disconnected. I cant therefore connect to...
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 15, 2010 | Canon Cameras
Can I download pictures to a computer with Windows 7 with my FinePix Z10fd digital camera?Is it compatible? I get an error message when I start the download process. (I had no trouble on my XP computer).
It doesn't matter to the camera what operating system you have on your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
May 18, 2010 | Fuji FinePix Z10fd Digital Camera
"Device is in use by another program" error message
Consider NOT connecting your camera to your computer.
Mar 03, 2009 | Canon PowerShot SD600 Digital Camera
Will not transfer pictures to PC
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
Jan 19, 2009 | HP Photosmart M417 Digital Camera
Cannot download my photos to my computer any longer
I CANNOT DOWNLOAD PICTURE FROM MY CANON DIGITAL IXUS 8OOIS IT KEEP TELLING ME THERE ARE NO PICTURES WHILES ARE PICTURE ON THE CAMERA.
Nov 28, 2008 | Cameras
Canon sd600 trouble downloading images to computer
Did you checked that your existing camera's drivers are supported the Win Xp OS ?
Jun 24, 2007 | Canon PowerShot SD600 Digital Camera
"Connection failed" -- USB connection
The "Connection failed" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me or 2000 to use a USB connection. Your computer must also have the appropriate USB connectors. NOTE: This camera cannot make a USB connection with a computer running Windows XP. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
"Camera not connected" -- USB connection
The "Camera not connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily identified: * Make sure that the computer's operating system is USB compatible. Microsoft Windows 95 and NT operating systems are not compatible with USB technology. (In addition, PhotoMAX and PhotoImpression software cannot be installed on Windows NT systems.) If you have an incompatible operating system, you must upgrade to Windows 98, Me, 2000 or XP to use a USB connection. Your computer must also have the appropriate USB connectors. * Make sure that the camera power is on. Follow the camera instructions to turn the camera on. Some cameras conserve battery power by turning off automatically after a few minutes of inactivity. If necessary, install new batteries or connect the camera to AC power (if it has an AC power adapter). * Make sure that the camera is correctly set to access images. Make sure the camera is turned on and that its mode dial (if it has one) is correctly set for transferring pictures to the computer. Refer to the camera user guide for more information. * Make sure that the camera cable has not been damaged or become disconnected from the computer. Confirm that both of the connectors are firmly attached. Check the cable for breaks, kinks or other defects, and check the connectors for bent or broken pins. If the cable is broken or kinked, obtain a new cable.
Sep 21, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
Can I use the PDC 640CF camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will not be able to use the serial port to download your photos. Only USB port downloads are supported under Windows XP for the PDC 640CF camera.
Sep 14, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
Largan Mega 2 Digital Camera Logo
90 people viewed this question
Top Largan Cameras Experts
Ekse
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Are you a Largan Camera Expert? Answer questions, earn points and help others
