Question about Whirlpool LEQ9858P Electric Dryer
Whirlpool dryer problem
I'm not sure of the model number the heating element does not work with the dryer running however, if the door is open and the timer is on it will heat up. If the timer is on and the dryer is not running again the element will heat up. Like if you open the door while its running close it and not restart it.
  • 1 more comment
  • cooper41 Sep 08, 2008
    trying to figure out why dryer is not drying properly? took heating element off but not sure how to see if it is bad? lint is free from every exaust exit! wondering if you can tell by looking at heat element if it is bad?
  • Michael Grimshaw May 11, 2010
    The whole scenario makes no sense. If I went to a home and a dryer did this, I'd figure on mice. I'd turn off the breaker before touching the machine and physically inspect the wiring and connections before I ever plugged it in again.
  • Ron Coons
    Ron Coons May 11, 2010
    wait wait wait. dryer not on,you open the door and heater is on????? yeat when you start the dryernothing heats up>??
Dryer works but does not heat up
Posted on Aug 11, 2008
  • 131 Answers
That's a good idea, Tech17. But isn't the heating element's L1 and L2 open when the unit's not running?
Posted on Mar 17, 2008
  • 1,314 Answers
Sounds like your heating element is broken and grounding to the cover take the front of the drier off and check the element after disconecting power
Posted on Mar 12, 2008
I have a Whirlpool Cabrio Gas Dryer, Model WGD6400SW0, I have changed the thermal fuse and the igniter, after changing but the on first run everything works, on next run no heat?
It may be the heating element leave door open and put a screw driver in where the door switch is and then turn on and you should see a glow where the heat comes out ; if no glow replace the element
Sep 05, 2017 | Whirlpool Dryers
How to fix Whirlpool duet dryer runs but does not heat?
The element is broken, you can pick up a replacement from any wholesaler of plumbing/electrical/appliance parts. Otherwise, there could also be an in-line fuse. if you look up your appliance on the internet ( a silver sticker on the lip or groove around the perimeter of the door has the serial number and model number) you can search the exact model number and find the manual, and then see if an in-line fuse exists. Otherwise, replace the heating element
Aug 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
What should we do? Our Whirlpool Thin Twin dryer doesn't get hot anymore.
You can fix it,, Here is an easy test and I can give you a definite answer on your problem and solution
open your dryer door, on the door you should see a little peg or clip sticking out which pushes into a corresponding hole in the on the front of the dryer. That's the kill switch for the dryer , it will click when you push it in, hold that in and turn your dryer on its highest setting.
Then look in your dryer while it's running , inside in the back you will see a lot of holes or slats in which the heating element pushes the heat through. You should see a slight glow and feel heat from those holes/vents, if not then I'm saying your element is out. You can normally order one through your local hardware/ appliance store using the dryers model number. For anywhere from ($20-$50)
Apr 29, 2014 | Whirlpool Dryers
MY dryer stoped working
I need your model number to be more helpful. You can start by checking your door switch if the dryer just won't start. You should hear a click from the door switch when you open or close it. If no sound then replace the switch. If the dryer runs, but no heat, often a dryers heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Here is a video to help you check for the problem.
Nov 26, 2010 | Whirlpool Dryers
Dryer does not dry as fast as it used too. Takes two cycles to dry a big load. Filters and exhaust are clear, and blower is still blowing. Looking in heat element, seems like botton 1/3 of coils don't turn...
Then part of the heating element is most likely not working because it is burned out or the high heat setting on the control no longer functions. Let me know the model number located most times inside the door on the wall of the door opening. That way I can Help you better, Thanks, Sea Breeze
Jul 13, 2009 | Whirlpool Dryers
Whirlpool dryer heat not working
Feb 24, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer
You need to check the dryer INTERIOR to ensure there's no lint accumulations on or around the heating element. The exhaust systems on dryers are not perfect and SOME lint often gets by the lint screen and can start the collect inside the dryer. The lint will begin to smolder and give off an odor if it sits on the heating element housing. Make sure the dryer is unplugged before attempting to access the interior. If the model number you provided is correct, the heating element will be located under the drum on the right-hand side. You will need to lift the dryer top and remove the front panel (with the door) to access the inside and vacuum. Let me know if you need further assistance. I hope this information is helpful to you.
May 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryer runs no heat
the kenmore is manufactured by Whirlpool. there are thermal overloads in the blower housing and one in back where the elements are. if these overloads open, 1) motor won't run 2) element won't turn on. check for an obvious open element.
Sep 13, 2007 | Kenmore 63942 Dryer
Whirlpool LEQ9858P Electric Dryer Logo
606 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
