Question about Panasonic TH-42PWD7UY 42 in. EDTV-Ready Plasma TV
42" pansonic plasma hdmi problem
I recently switched from Dish network to Direct TV. I think the new picture looks inferior to the old and as I was doing some settings searching, I noticed that my input on my TV didnt say HDMI any more? (I had installed the HDMI expansion card 1 year ago). Instead it said Component/RGB? I am getting picture and sound, and the only cable hooked to my tv was the HDMI cable, why would it say component/RGB? I run an HDMI cable from the direct tv box, through my pioneer reciever, then to my tv HDMI card. I THOUGHT the TV input used to say HDMI, but am wondering if anyone can shed some light?
Thanks
Chris
  • Anonymous Mar 23, 2014
    Have 2 hdmi cables. Trying to connect tv with direct tv and ps3. Please help.
  • Anonymous Mar 25, 2014
    Only the RGB cables work on the circuit board. No HDMI or composite connections work.
  • 45 Answers
If I understand your question properly.. its because your direct tv output doesnt broadcast in high def so its giving you the standard tv definition inputs which are RGB or Component.so you will lose picture quality cos its running at fewer lines or pixels. hope this helps
Posted on Mar 25, 2008
6ya staff
SOURCE:
DHCP
Hi Harryward_26, my name is Cheri Torres and I work on the Social Media Team at DISH. In order to comply with movie industry standards, DISH network, as well as all TV providers, must enforce content protection standards when required. This message indicates that your TV or connection is not High bandwidth Digital Copy Protection (HDCP) capable. It is likely your TV was manufactured before industry standards required HDCP. In order to resolve this issue you would need to replace your HDMI cable with component cables (red, green and blue). Once you do this you will be able to view the content. If you have any further questions or concerns feel free to email me direct at [email protected] Thanks!
May 05, 2012 | Philips 42pf9966 42-inch Hd-ready Flat...
How do I connect my LG TV to my dish network
Hello Al, my name is Cheri Torres and I work with DISH Network Internet Response Team. I came across your post and wanted to see if I could help. Connecting your LG TV to your DISH Network receiver should be fairly easy, depending on the connections you are using. If you are using an HDMI cable you will need to connect one side of it to your LG TV and the other end into your DISH receiver, as long as you have an HD receiver. If you do not have an HD receiver you are probably going to want to use composite cables(red, white and yellow). If you are using either of these cables you are going to have to set your TV to an input in order to receive the DISH picture. You can select an input by finding a button on the TV remote or the TV itself that is listed as input, source, AUX, mode or video. You will need to cycle through each one until you find the DISH picture on one of them. Once you have the picture you will need to press SAT on your DISH remote and everything should be working fine from there. I hope this information is useful and if you have further questions feel free to ask!
Dec 31, 2011 | LG 42PG20 42 in. Plasma HDTV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
I have an element 42" plasma, we were watching a
staceydesjar
Try unplugging the receiver from your electrical outlet for 10 seconds and plug back in. This will cause the receiver to reboot and re-acquire the satellite signal. After this, you should get your picture back. I hope this helps.
Ray Calo
DISH Network
Dec 30, 2010 | Element Electronics PLX4202B 42 in. Plasma...
New TV is hooked up from satelite cable via HDMI wire. We have it plugged in the HDMI port # 1. When we turn on the cable, the little box pops up saying HDMI and 480P. I ready the specs for the TV and...
jason_janick
You have settings in your TV and satellite receiver to set the resolution for the picture. I would first go into the TV settings and use 1080p for the TV resolution. Also, in the receiver setting, you have the HDTV setting. From the main menu, press 6 (System Setup) and then 8 (HDTV Setup). For TV Type change to 1080i. The Aspect Ratio should be 16:9. I hope this helps.
Ray Calo
DISH Network
Dec 28, 2010 | Element Electronics PLX4202B 42 in. Plasma...
Vizio TV no picture, it will come on and has some display but no picture at all just a grey looking screen. Cannot even see displays when switching from HDMI, AV, etc. This happened after a lightening...
Vizio panels are especially delicate when it comes to under or over voltage spikes, I would say that the LCD panel has failed and will probably cost approx. 80% the cost of a new television, I have experienced that Vizio TVs are a tuff one to get service on in my area, so you might call vizio direct and talk with one of their service reps.
GOOD LUCK !
Aug 23, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Sound
I have a42hds52a and someone threw something at the screen and broke it. so I am looking for someone who is willing to get rid of thier tv1.gif or looking to buy one for parts.
call Richard At916-308-9272
[email protected]
Sep 10, 2007 | Hitachi 42HDT52 42 in. Plasma HDTV
No Video
have you gone through the menu to assign which signals the receiver recognizes?  I had to change the source when i switched to the Dish Network HD receiver.
Aug 24, 2007 | Pioneer VSX-1016 Receiver
Panasonic TH-42PWD7UY 42 in. EDTV-Ready Plasma TV Logo
519 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
