Ijust purchested a new computer and the sound does not work right when I tested it with the Audio manager it works fine
  • 36 Answers
You'd've muted the audio device.. if its xp, double click the volume icon in the systems tray ( right end of the taskbar) and check whether the wave device is muted.. if not, chek whether ur media player software is fine.. if its not fine chek with some other media player.. if all of them are righ, reinstalling the audio drivers will help you..
Posted on Mar 12, 2008
SOURCE:
I have no sound and i can not see the volume control
It's a possible problem with the driver or the sound card may be disabled. To check if the sound card is disabled or drivers not installed,
1. Right click on "My Computer" select "Properties"
2. Click "Device Manager"
3. From the list, you should see a "Sound Controller" and if you click on the drop down arrow beside it, you should see the audio driver installed(ex. High Definition Audio Device... audio driver name may vary depending on the brand of the laptop).
4. Right click on the sample "High Definition Audio Device" then select Properties. If it says device is working properly then there shouldn't be any problem with your audio.
** If the Sound Controller is NOT installed properly you need to download the Audio drivers from the support site of your Dell computer, http://support.dell.com , be sure to select the correct model of your laptop and operating system of your computer. Once you have downloaded and installed the drivers, Audio should work fine not unless it is the hardware itself that is damaged.
**Also don't forget to check if there are other external audio output devices connected to your computer, please do test if working properly.
Hope this helps. Glad to be of service.
Nov 23, 2011 | Dell Computers & Internet
Hi there I have a Tevion 2800 Video Capture Adapter on XP Windows computer. I can hear the audio ok on My HP D330 PC computer for other audio things like cd and windows startup etc. But when I capture the...
Thank you for availing our service and welcome to Fixya
With your concern there are two things that we can consider that is causing the problem here, first is that with those 2 video capture card or the sound card of your computer itself that may need a driver update.
First thing that we can try here is to do an update on the driver for the sound card of your computer, if you know how to access device manager we can do it from there.
Follow these procedure to open device manager, Right click My computer icon > properties > Hardware > Device manager.
Once you have device manager open Go to Sound, video and game controller then look for your audio device and from there please do right click it and then click uninstall and then once done you go ahead close everything and restart your computer then test it now if still the same problem.
Oct 11, 2011 | Computers & Internet
I can not get sound on my computer at work and i dont know why. tested them on my neighbors...they worked fine. Please help. Thanks, Kim
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 23, 2011 | Insignia NS22 2 Speakers
I have pluged all speakers but not sound on the front and rear to working when i play test they all working but not when i open a music from windows media player.
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 11, 2010 | Logitech X-530 Computer Speakers
I just bought a computer and the first day the speaker was working fine and now i cant hear any volume i checked everything making sure its not in mute
the drivers might have been corrupted by something or you might have got a virus run your antivrus program and test for a virus then
you might have to uninstall then reinstall either the sound drivers or the sound card make sure you have both of these devices baked up to a disc before uninstalling
a yellow? question mark means you need to install/update driver right click to install driver
as for the sound
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 28, 2010 | HP (PP036AA) Computer Speakers
Speakers dont work, led controls dont light up, diagnostic test does not work. My connections are correct and my drivers are updated. What is wrong?
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 28, 2010 | Altec Lansing ADA 885 Computer Speakers
My laptop's audio has stopped working, and the audio area says that the speaker is working and the sound is on, but nothing plays, not even the test tone. I think it is a driver issue. The speakers are...
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
or
hope this helps
Nov 11, 2010 | Computers & Internet
Audio
if audio is not working// follow all this steps:-
1)check for mute button// it should be on//
2)control pannel/sound icon double click// check default speakers/ test the sound
3)uninstall the sound driver from device manager by clicking on the plus sign and right clicking on the poped driver/ restart the computer/ check by playing the sample music it should work//
how to go to device manager?
xp comp; right click on computer/properties/hardware/device manager tab
vista comp:- type device in start search at the bottom after u click on start button. device manager will be populated on top click on that and the window will open.
May 07, 2010 | Compaq Presario 700 470024-192 Notebook
No sound output except for during test.
Did you check in control panel on the status of your audio settings?
Open audio devices in control panel. click on advance , then click on the drop down bar and select 5.1 . click apply,then OK then and close it .
post if that does not do it.
First unplug the speakers, and then go to the page of the manufacturer's,.
if you cannot find the disc with the drivers.,and download s new copy of the drivers..
Then install it and then shut down the computer and plug in the speakers.. that should do IT.
Nov 05, 2009 | Logitech X-540 Computer Speakers
Asus M2V Audio problem
put your hand on chip of your sound card on board if its hot so sure you need to disable and buy sound card or replace this chip also check audio jumper on board and try to install windows again and install the driver if u see on task bar sound volume icon check by tested headphone if there is out sound or no i wish i helped u
Jan 02, 2009 | ASUS M2V Motherboard
Open Questions:
Aol email technical support contact 18OO-8O3[[1O69]] number*v*~u.s.a rrdf Usa AOL USA phone number is ranked #2 out of 2 because 7,728 AOL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO::8O31069 is to reach t he AOL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AOL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL USA Calling AOL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL USA's phone numbers against each other. Contacting AOL USA in General While I8OO8O31O69 is AOL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL USA.
Oct 19, 2019 | AOL Computers & Internet
Computers & Internet Logo
94 people viewed this question
Ekse
Alun Cox
