Board problems I can't get board to boot and it can't find fdd cd rom nor hdd.I would like to know what I am doing wrong in setup or hookup.I reinstall old board everything worked fine,but some where is a problem that wil not show itself.I love this board but how to fix the problems
  • 36 Answers
Chek whether the connections from the smps are right and chek whether the cables connected to the board are intact.. the smps may be incompatible with your board or will give it low power so that it cannot start.. check whether the mother board is deviod of all metal contacts and chek whether u've secured the board to the cabinet using the plastic jumpers..
Posted on Mar 12, 2008
SOURCE:
Foxconn N 15235. From cold start cannot find boot device, after ctrl alt del it reboots. CMOS battery replaced. Problem persists. Only 1 HDD Sata and no CD Rom / FDD intalled
make jumper setting to your hdd u will see at the front of the hdd the jumper settings before u"ll do the job unflug the power supply
Jan 20, 2011 | Computers & Internet
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
How to configure theh bios to boot to cd
when u power up the computer press "del" or F2 to enter in bios
then go t o boot option set first boot device as dvd drive then presss F10 then save all settings then it boot with dvd or cd
May 22, 2009 | Computers & Internet
I am Having problem restoring my dell 2400
Well you may have a bad mother board or IDE port to which the HDD is connected. If the CD is connected to the same IDE channel as the HDD, move it to IDE1 which is the second IDE channel. If it then recognizes your CD, IDE0 is bad and you need to replace your board. Let me know how things are connected inside the computer.
Apr 14, 2009 | Computers & Internet
Satellite A20---is it possible to boot from external burner
you can try to install throu USB Drive. Search google there are many tricks how to bootup with your Pen Drive.
Feb 27, 2009 | Computers & Internet
My cd rom wont boot up at start up
1) Has it ever booted from CD-ROM? If it has, go to step #2. If not, go to step #3
2) If nothing has changed (BIOS, hardware additions, etc), it's a bad CD drive
3) Check your BIOS "boot order" section. It varies from motherboard to motherboard, but all BIOS's have some type of boot sequence that you can configure. It's possible that yours may be FDD, HDD, CDROM (in that order), which means that as long as you have a working Windows computer, it never needs to boot to CD. Try changing the order and that should fix you up :)
Hope this helps :)
Scott
Oct 08, 2008 | Computers & Internet
Re: lg tower xp install
the boot device setup in the bios, if you set atapi-cd rom as first boot device. then hdd second. and fdd last.
it appears that you have a faulty connection from the IDE ( 40-80 wire cable ) that runs from the motherboard Primary/secondary slot. check the cable goes from motherboard to hard-drive and is connected firmly, also check the jumper blocks ( small white plastic block ) is set to master or slave on both devices ( cd-hard-drive ) if both on same cable set hard-drive to slave and CD rom to master. if they are both set as master or slave, they will conflict with each other.
if you need further help, please mail back.
mike @ compurepair.
Mar 29, 2008 | Computers & Internet
Is the 2400 Toast ???
Two main reasons why this things happen, first.. there's an error with your hardware. If you know how to diasassemble your pc, then do it. Cleaning your machine will make it work. If it doesn't, repair the operating system with your windows installer cd. Be sure to clean your cd rom or you might as well borrow or buy a new cd rom so that the installation will run smoothly
Dec 05, 2007 | Dell Dimension 2400 PC Desktop
Open Questions:
Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7Avg TeCh SUpPoRtPHoNe NuMbEr+1*888 [ 499} ~5520 $ HeLp.24*7
Oct 16, 2019 | AVG Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
