Sanyo fascimile Hi My keypad for fax machine is not responding at all i need help
  • 82 Answers
When you not responding you mean not one of the keys anywhere on the panel or just your dial keys. if one of either is stuck down which is simple to fix. used tooth brush wet not soaked in rubbing alcohol and clean all the edges of all the keys
should free it up. if that doesn't work removal of control panel and cleaning/checking keys are clean doesn't solve it then you have a blown key pad circuit board.
mikey
Posted on Mar 16, 2008
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
I have a brother fax, model 525 DT. When you hit the number key for 7, it does not respond. In other words, that number does not appear in the window. As a result, the fax number is incomplete and fax...
Unfotunately you probably already know the solution here. The keypad needs to be replaced. There is a way to get into the pad and attempt to fix the individual key itself, but if you are here posting this, I'll simply assume that you don't have the technical skill required to fix that individual keypad.
If you purchased it recently, I would go to brother's website, find their support number and call them. It MAY still be under warranty. They can also advise you of any pricing and installation costs associated with replacing the keypad. I have over 20 years experience on office equipment, and I HIGHLY stand behind Brother and their services. Their support is very friendly and will help you... ;)
www.brother-usa.com
Sep 03, 2011 | Brother Office Equipment & Supplies
I need new cutters
Hi, Please tell me the details that you need. I can not get which cutter you need.
Aug 26, 2011 | Office Equipment & Supplies
Hi my name is Emily I have a question for office procedures module that I am studying at TAFE. I looked this up on the internet, however the site where I can access this information is being...
Hi Emily,
Click here to download the User Manual General Setting Guide for Ricoh Aficio MP161SPF. Please refer to Fax Section (4) for the required details about setting up fax.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 03, 2011 | Office Equipment & Supplies
Brother Personal FAX 275 keypad problem
the button might be a little sticky if you get a little bit of glass cleaner spray it by the button and let it sit for a minute the keep pressing teh button lightly a few times it should clear out any gunk on teh button failing that if you know how to take the cover off you can clean it that way .. if it still sticks try swapping it for a button you dont use you will ahve to take the button off by desoldering it and swapping
Sep 29, 2009 | Brother Personal FAX-275 Roll paper...
No dial tone when sending fax
PLESE CHECK TO SEE IF YOU HAVE DIAL TON TO ANOTHER PHONE, OTHERWISE THE PHONE BOARD CALL THE NCU BOARD MAY BE BAD
Jan 06, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Key pad
A couple of things. Make sure none of your keys are stuck. One key being stuck will disable the keyboard. Carefully depress each key individually and see if one of them is responding differently.
If you want to try, and its not overly difficult, remove the keyboard and unplug and re connect every connector and ribbon cable you can find. Often one of them becomes loose or has a so so connection that can cause it not to respond.
Let me know please.
Mar 11, 2008 | Brother IntelliFAX 4100 Laser Fax
SANYO Facsimile manual,free
Ring SANYO OCEANIA on Australia: 1300 728 748 and ask them what you need to know. They will give you answers for free!
Dec 27, 2007 | Office Equipment & Supplies
Help me.....
The trouble is:
when I copy, only come out solid black pages
Nov 01, 2006 | Brother IntelliFAX-870MC Fax
44 people viewed this question
jasbo
jasbo
