Question about Mitsubishi WD-57731 57" Projection HDTV
Wd57731 won't power up
I have a wd57731 and got the replace lamp message a couple months ago. The lamp finally failed and was replaced with the one that was recommended now, but is not the one listed in the owners manual. (I was told these changed resently). After a couple on/off cycles, the tv would not turn on and depressing the reset button did not cure the problem.
  • Mitsubishi Master
  • 8,617 Answers
Have you checked the air filter? Did the set operate normally after replacing the lamp?
Posted on Mar 12, 2008
Buick 97 LeSabre hard start and acceleration issues
Have you checked the catalytic converter? After 20 years they do pug up causing some of the problems you describe
Apr 09, 2017 | 1997 Buick LeSabre
My HL-P5063W won't power on. I replaced the Digital Video Board and the lamp. When I power up the the TV, there are several clicks and never a picture. The lamp does not appear to getting any...
Did u ever replace the Ballast board for this tv?No?,that ur tv problems.The Ballast board only job are to ignite the tv projection lamp to make it work.U hearing multiple clicks,lamp never ignite up the Ballast board.
Jul 29, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
A message appears when the set (LCD) is turned on whichstates that the lamp should be replaced but it is workning. Replaced the lamp 11 months ago and it has a 1 year warranty. What is the purpose of the...
that lamp timers are only there to give you an idea that the lamp may fail soon. the tv will count to a certain number of hours and then give the message on screen. most tvs the number will be around 4000hours or so. i suggest using the tv until the lamp fails you may change a lamp that has many many many more hours when you dont need to. there is a timer that you can reset if you consult your owners manual so the message will not show up any longer.
Dec 23, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
Replaced lamp on WD57731. green light turns on then a ornage light, under lamp blinks
Please put back lamp cover, the last plastic grille that were removed to replace lamp in TV.
TV sense that lamp cover is not either put back or not fixed properly so it wont turn On. Check lamp cover and problem will be solved.
Thanks.
Nov 14, 2009 | Mitsubishi WD-57732 Projection Television
Just replaced bulb to a phillips, lasted one month
Most systems with lamps will have a timer. If the timer gets to a certain hour the set should warn you to replace the lamp. Once you do, you have to reset the timer. If it gets to the max it will not allow you to turn it on till the timer is reset. Check your manual or call the mfg. to see how to reset. Sometimes it's the volume up and down at the same time or menu and power at the same time. They are all different so if you have no manual it's best to call tech support to get the reset steps.
Jul 17, 2009 | Panasonic PT-50LC13 50" Rear Projection...
DLP Lamp Replacement
in the rear their is a section were you can uncrew and replace the lamp. be sure that its unplug from the ac outlet and you wear a glove so you wont touch the lamp.
Apr 01, 2008 | Televison & Video
Lamp automatically turns off
Hi there
Did you reset the lamp timer ?
Jan 24, 2008 | InFocus IN72 Multimedia Projector
PT-50DL54 panasonic 50" DLP
to get rid of "replace lamp" push the blue action button on the remote and the volumn down on the tv set for a couple of seconds. this has to be done at the same time, good luck.
Bob
Dec 09, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Mitsubishi WD-57731 57" Projection HDTV Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
