Connecting a older fax machine
Can we connect fax machine to telephone land line with a splitter?
  • 168 Answers
Yes you can and it should work fine.
If it is not working, then please submit another question with the problem that you are having.
Hope this helps.
Good luck.
Mac
Posted on Mar 13, 2008
I have fax problem in my multi-function panasonic printer machine, all the power and rest functions are working other than fax, I am not getting the line dial tone when pressing monitor even the faxline is...
See Page 72 of the User Manual available here:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Multifunction-Printers/How-To-Guides/model.KX-FLB801.H#ts
I cannot hear a dial tone.
The telephone line cord is connected to the [EXT] jack on the unit. Connect to the [LINE] jack (page 21).
L If you use a splitter/coupler to connect the unit, remove the splitter/coupler and connect the unit to the wall jack directly. If the unit operates properly, check the splitter/coupler.
L Disconnect the unit from the telephone line and connect a known working telephone. If the working telephone operates properly, contact our service personnel to have the unit repaired. If the
working telephone does not operate properly, contact your telephone company.
L The power cord or telephone line cord is not connected. Check the connections.
L If you connected the unit through a computer modem, connect the unit directly to a telephone line jack.
I cannot make calls. L The dialing mode setting may be wrong. Change the setting (feature #120 on page 22).
The unit does not ring. L The ringer volume is turned OFF. Adjust it (page 23).
Hope this is helpful. ;)
Dec 10, 2010 | Panasonic KX-FLB801 All-In-One Laser...
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
Hi my machine wont send or recieve a fax despite being properly connected. printing from computer is fine. has worked fine up until today
Hi check the following article to from HP
Problems with sending and receiving FAX
HP FAX ISSUES
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 05, 2010 | HP Photosmart 2610 All-In-One InkJet...
How do I use the fax without going thru my computer just as a fax
Issue: How do I connect a telephone, answering machine or computer modem to my machine?
Solution: Connecting the telephone line and external devices to the MX310
Preparing the Machine for Faxing title-bar.gif Typical examples of connecting the machine are described below. The machine cannot send/receive faxes if the connection is incorrect. Connect the machine correctly.
i_important.gif Important
If the Power Disconnects Unexpectedly
If there is a power failure or if you accidentally disconnect the power cord, the date/time settings as well as all documents stored in memory will be lost. User data and speed dialing settings are retained. If the power disconnects, the following will apply:
bullet_s.gif You will not be able to send or receive faxes or make copies.
bullet_s.gif If a telephone is connected to the machine, you can receive voice calls.
bullet_s.gif Whether you are able to make voice calls depends on the type of your telephone.
sikaku.gif Methods of Connecting External Devices bullet.gif Connecting to an Analog Line t_01522.jpg
(A) Telephone line (analog)
(A) Telephone or Answering machine
Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A) . The machine may not operate properly.
bullet.gif Connecting a Telephone or Answering Machine via a Computer t_01724.jpg
(A) Computer
(B) Telephone or Answering machine
sikaku.gif Methods of Connecting the Various Lines The following are some basic connection schemes that apply when you are connecting to a non-analog telephone line. These are examples and are not guaranteed to suit every connecting conditions. For details, refer to the instruction manual supplied with the network device (control devices such as an xDSL modem, terminal adapter, or dial-up router) you are connecting to this machine.
(A) Digital Subscriber Line
(B) Splitter
(C) xDSL modem (splitter may be built-in to the modem)
(D) Computer
bullet.gif Connecting to an ISDN Line For details on ISDN connection and settings, see the manuals supplied with your terminal adapter or dial-up router.
Please be informed that you can access Canon's online support site for your printer by clicking here. You can find many solutions to your problems by searching their database once you have navigated to the support page for your model.
I hope this information allows you to resolve this issue. If not, reply back with a comment to this thread.
If so, please take just a moment to rate this post. Thanks!
Apr 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Connecting Linksys wrtu54g wireless router with Linksys SPA 2102
If you want to receive "incoming" telephone-calls:
ADSL modem <---> Linksys SPA <---> wrtu54g <---> wired computer
and Linksys SPA <--- telephone-line-1 --> telephone hand-set
and Linksys SPA <--- telephone-line-2 --> FAX machine
or Linksys SPA <-- telephone-line-1 --> mechanical telephone-splitter
with telephone-splitter --> hand-set
with telephone-splitter --> FAX
Mar 19, 2009 | Linksys Wireless-G Broadband Router
Telephone line connection
Two options:
1) Pick up a phone line splitter (Radio Shack or just about any other retailer has them) that has a plug on one side and two jacks on the other. Plug this into the phone jack where the line to your computer is connected. Plug the cord to the computer back into one jack on the splitter and plug the line to the fax machine into the other jack. (If it will physically fit into the space on the back of the computer, you can just plug the splitter into the modem connector, plug the line cord into one jack and the fax cord into the other.)
2) (Useful if the phone jack is behind furniture or just hard to get at.) Get a phone line splitter with all jacks (two on one side, on on the other). Unplug the line cord from the computer and plug it into the single jack on one side of the splitter. Then run a new line cord from one of the two jacks on the other side back to your computer. Plug the cord to the fax machine into the other jack.
Jan 27, 2009 | Dell A940 All-In-One InkJet Printer
Canon MP830 - Outgoing fax dialing not connecting
Are you plugged into the LINE port of the fax machine?
Oct 21, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Connecting
jon, I am assuming you have DSL modem. Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. Good Luck, Tim
Feb 03, 2007 | Lexmark X4270 All-In-One InkJet Printer
24 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
