Question about Dryers
Maytag dryer Not the blower wheel....no clog spins fine..now what, any other suggestions. Is there anything with the gas assembly that would let it flow the wrong way?
    Novelist:
  • 131 Answers
The blower wheel draws air into the machine past the burner, up through a channel in the back, into the basket, out through the lint screen to the blower wheel and then out the back of the machine. If it is clogged somewhere, the flame will stay in the burner chamber until it activates a high temperature thermostat.
By the way, when you have the machine taken apart, this will disrupt the normal air flow. You must have the basket and front ring in and the door in place if you want to test it with the front panel removed.
Unless the motor is turning backwards, it will draw the flame toward the back. And I've never seen a motor turn the wrong way. They're made to turn one direction only - even if you hook them up 'backwards.' Was the motor changed recently? Could you have the wrong part in there?
Now I'm curious. Be sure to comment back on what you find, will you?
Posted on Mar 12, 2008
Blower wheel bad on may tag dryer
anything involving gas have a certified technicien to do it,anything goes wrong your safety is at risk
Feb 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer not producing heat
Might be a fuse due to a clogged lint buildup or possibly a bad blower wheel itself. On a gas dryer the fuse only kills the gas assembly. The motor will still work and the dryer will still operate with a blown fuse. If it heats a little bit and quits it could very well be the solenoids.
SLOPEFACE DRYER MANUAL
Aug 30, 2012 | Maytag Dryers
I have a maytag heavy duty gas dryer model number LDG412 i need to know how to clean the vent all the way to the duct, the dryer is getting hot but it is taking a long time to dry clothes now, inside where...
while cleaning the venting is never a bad idea and i recommend its done yearly,a common problem with older (the ldg 412 is from the mid 1980's) Maytag dryers isa stripped drive hub on the blower wheel and absolutly no air is being circulated throughout the dryer. A lot of times when starting the dryer and when it stops a rumbling noise will be made if the blower wheel is the problem. To check it if is the blower wheel you can remove the front panel by removing the screws that are a slight angle at the bottom of the front panel,tilt it out toward you at about a 45degree angle,then off. At that point remove the four 5/16" hexhead screws holding on the front drum support,lift it up slighly then off. The blower wheel will be in the lower left corner and you could spin it by your hand if it spins around the motor shaft it slips onto and does not move the drum while turning the blower wheel,it is stripped and needs to be replaced.To replace it remove the 1/4" hex head screws that hold the front plate to the plastic blower housing(7 screws) and the 5/16" hex head in the tab also in the plate in the front of blower housing the plate where come off. To replace blower wheel remove the greenish/black clamp from the center hub and the thin metal ring that fits ina groove on the motor shaft, a special c/e clip ring pliers are needs to remove the ring. A inexpensive pair could be picked up at most places that sell tools(ace hardware/lowes/home depot/sears) The part number for the blower wheel is 303836 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
assuredparts.com
I hope this will help you to repair your dryer,
Gene
Aug 07, 2011 | Dryers
My Maytag atlantis MDE7600Ayw takes nearly 3 hours to dry clothes. The back silver metal grill is very hot and it still tumbles, no weird sounds. Any suggestions?
sounds like your vent is clogged or there is lint clogged around the blower wheel. Make sure to check outside where it comes out and be sure all the exaust tubing is free of lint clogs.
May 01, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer starts slow with rrrrrrrrrr noise and timer does not move
This could be a simple repair. The blower wheel in the exhaust housing maybe free spinning on the shaft. If it is replace the blower wheel. If not the motor has gone bad.
Feb 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The motor hums but if i take off the tension spring the motor spins fine
if you mean you disconnected the belt and the motor spins you could have something stuck in the blower wheel like a sock or something,you might have had the filter out and ran the dryer and something went down into the blower wheel,also the motor still could be bad not strong enough to spin drum
Nov 02, 2009 | Maytag Dryers
Have a 7 yr old maytag dryer it seems to heat up fine and everything but we have to redry clothes 2 or three times and dryer vent is not plugged
You possibly have a stripped blower wheel . On Maytags , either blower or clogged vent is the problem when too long to dry . Suggest removing vent hose and feel if you have good exhaust air . If not , blower wheel bad , if so , vent problem . Try drying a load without vent hose connected to dryer .
Jul 06, 2009 | Dryers
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Blower wheel loose on shaft of motor on maytag dryer
GO TO www.repairclinic.com and enter the model number look for your blower wheel item 1245880 it looks as if there is a flat side on it. this may help ya Good luck
Apr 09, 2009 | Dryers
Dryers Logo
42 people viewed this question
Top Dryers Experts
