Question about Panasonic PV-V4021 S-VHS VCR
I have a PV-M2767 Panasonic Omnivision VHS
Dear Sir or Ma'ma:
What channel does the TV has to be on to play a DVD or a VHS movie. I have this unit, Magnavox DVD/CD Player with Video Cassette Player.
I cannot view VHS movies or a DVD movies on the TV.
Can you help me?
You can email at prayingangels2004@yahoo.com
Sincerely Sandra Bliss
5 Suggested Answers
  • 275 Answers
SOURCE: panasonic pv-v4021 VCR
Actually George, You should read the supplied Operations manual. In that you will find a chapter for using the Remote as a Universal remote, and a list of codes will be give. Check out the code for Misubishi TVs and feed that.
Posted on Mar 21, 2007
  • 11 Answers
SOURCE: Panasonic omnivision PV-V4021
Read the book. ........... Get one.
Posted on Sep 28, 2008
leecom72
  • 4806 Answers
SOURCE: the cassette is stuck...
the tape is trapped in the mechanisms, you have to strip the VCR down to get the tape out
regards
Posted on Nov 26, 2008
Grubhead
  • 4593 Answers
SOURCE: Have PV-8401 VCR plus Omnivision VHS but missing
Ok there's a lot!
1005, 1021, 1043, 1085, 1160, 1161, 1210, 1218, 1219, 1242, 1248.
Please bear in mind some codes will operate some functions but not all, you might need to check different operations before you get the right one.
Posted on Oct 14, 2009
Grubhead
  • 4593 Answers
SOURCE: panasonic omnivision pv 4651 no video signal but
If you mean during playback, then all you need to is clean the Video Head with Servisol Video 40.
Posted on Jun 14, 2010
How to get my VCR menu from French to English
the language can be set by going into the setup menu for the unit using the channel buttons and follow the prompts on the screen.. if it wont go there either unplug it and reset it or put a tape in..
Jan 26, 2014 | Panasonic Pv-4501 4-head Omnivision Vhs...
Want to copy DVD to tape
If you are trying to copy a commercial DVD then you will not be able to. The only way that you can copy one is to connect an outside VHS player to it. But you will also need a special box which will defeat the macrovision. They are cheap though. Search online for one.
Feb 24, 2013 | Panasonic Pv-d4735s Dvd/vcr 4head Hi-fi...
How to set up my old vcr to a panasonic tv and get it working.
The VCR should set itself up. But if it doesn't have a digital tuner then it will not find any stations. You will just have to cancel that bit and do the rest. You can connect a set top box to the scart socket 2. If you want to record you have to set the timer manually and set it to record scart 2 not a channel. If the VCR has PDC set it to off.
Dec 05, 2012 | Panasonic Pv-v4530s Vhs Vcr Omnivision
My VCR say VCR Lock actavaited how do i get that off because it wont play
Try Pansonic website USA they might have a free PDF of the user manual. I have looked on the UK site and it's not there.
Nov 14, 2012 | Panasonic Omnivision PV-7401 4 Head VHS...
Panasonic omnivision pv 4651 no video signal but audio is fine
Jun 14, 2010 | Panasonic PV-4651 VHS VCR
How to record movies from the tv to my Panasonic PV V4521 vcr
If you need the user manual you should be able to get it free from the Panasonic website.
If not can you explain the problem more clearly, for instance are you trying to record digital channels and the vcr has not got a digital tunner etc?
Dec 27, 2009 | Panasonic PV-V4521 VHS VCR
Panasonic PV-7451 VHS
I don't recognize your first problem.  The "light to dark" issue I believe is intentionally engineered (mine does it too); it prevents recording DVDs on to tape.  Try running the DVD player directly to the TV.  Radio Shack used to have a box that would correct this issue too, you might check there.
T. R.
May 18, 2008 | Panasonic PV-7451 VHS VCR
Apr 17, 2008 | Panasonic PV-V4021 S-VHS VCR
Panasonic PV-V4021 S-VHS VCR Logo
479 people viewed this question
Top Panasonic VCRs Experts
Pieter Vleeshouwers
Are you a Panasonic VCR Expert? Answer questions, earn points and help others
