Question about Refrigerators
Fridge I want to buy a refrigerator for our home. I want ot ask you what is the diff. between green ion door cooling & ice beam door cooling. Which one is the best in India & which brand i should buy.
  • 552 Answers
Http://www.compareindia.com/products/refrigerators/
This link should serve you well for your question.
Hope this helps.
Posted on Mar 12, 2008
I have an LG French door refrigerator Model LFX28978 ST/00. I noticed that there is ice in the ice tray but it is not dumping it.I turned it off and on and it moves freely, but does not dump the ice.
Sorry to tell you that LG makes the worst refrigerators of all time. The control panels have CONSTANT problems. I suggest you buy a home warranty that covers refrigerators.I had the big 31 CF Kenmore (made by LG). Sears came out THIRTEEN times trying fix it. They replaced the coils twice, the control panel twice and the refrigerant-line fluid filter 3 times. Finally they gave me $1000 to throw it away.
AS A WARNING TO SHOPPERS!!!!!!! You should stay away from high efficiency refrigerators!! They gain that efficiency by reducing the cooling capacity. The walls of heat exchanges are much thinner, leading to leaks. Ask any fridge repairman. All this leads to breakdowns after only a few years of service, because they are so fragile..
May 15, 2017 | LG Refrigerators
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
Deawoo fridge freezer FDF-358 freezer is cold, fridge is not getting cold
The freezer section is working,but fridge is not because defrost door is blocked.Its a defrost cycle issue.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Why is green light flashing
Its indication of overfreezed fridge or freezer unit.Or any door not getting closed properly.
These will help.
Thanks,.
Dec 21, 2012 | Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
I own a lg ice beam door cooling fridge for the past five years since recently the fridge is not cooling properly when i open the firdge i see the fan inside the frdige is at standstill pls advice also the...
sounds like u have a deforst problem. if it dont automatical defrost then u have to manually do it then u will have to replace the defrost timer and hope your defrost heaters are still good. ok
Feb 12, 2011 | Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Freezer is cold fridge is not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 02, 2010 | Kenmore 57029 Side by Side Refrigerator
Double door fridge stops cooling, autodefrost not working
It wud need a new defrost heater, the fridge gets its air from the freezer , if the defrost heater does not work , ice builds up in the airduct , equals to no cooling in fridge
Feb 01, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
