Question about Kirby G6 Bagged Upright Vacuum
Kirby Vacuum Fan
Is the fan on a Kirby Vacuum free floating on the shaft? The shaft accelarates faster than the fan. Do I need a new fan?
    President:
  • 1,673 Answers
The pullet is what holds it in place, if it has come loose, just tighten it. But if that doesn't help, then replace the fan.
Posted on Mar 13, 2008
How do I remove a stripped fan blade on Kirby ultimate g
I do not know of any screws that would be stripped right at the fan. Here is a walk through on removing and replacing the fan, the shaft needs to be turned counter clockwise.
Kirby Fan Replacement
800-775-6586
GoodVac com
Oct 03, 2014 | Kirby Ultimate G Bagged Upright Vacuum
Replace fan
Replacing a broken fan in a Kirby is not an easy job. You have to take off the handle, the top cover, the front piece covering the fan and then stick a wrench down onto the motor shaft to hold the shaft tight while you stick an awl or small screwdriver into the hole on the spindle sticking out the front of the vacuum. Turn the spindle to remove it so you can remove the fan. Install the new fan and reassemble the vacuum.
Mar 11, 2014 | Kirby Vacuums
How do i rectify the shaft coming off the motor shaft
sounds like the fan has melted. you will need a new fan kit it comes with a new drive pulley. (about $20)
Mar 08, 2014 | Kirby Generation 3 Bagged Upright Vacuum
I watched video on replacing the fan. I am a grandmother and have never replaced anything. Everything went fine until I tried to remove the shaft holding the fan in. I keep turning the shaft to the...
those video's aren't detailed enough. You have to take apart the other side too. Follow the directions on this page and you should be able to do it. You can order a new fan on amazon for about $12.
http://www.greatvacs.com/education/kirby-fan.html
Oct 21, 2013 | Kirby G4 Bagged Upright Vacuum
Our Gen3 Kirby still works but is extremely loud not - I am currently only using with the wood floor attachment (no brush) - thoughts?
this could be the impeller fan next to the motor shaft under your attachment hose connection.
to determine this, remove the hose from the unit, and turn the fan shaft with your hand looking down inside the unit. You should see blades on the impeller fan, and they should all look squared off and curved. If any of them are broken or worn, it will make the unit louder than normal.
Also, the hose attchment has an increased noise more than using the brush attchment anyway because it increases the suction for the hose more than on the carpet. IE the motor runs faster giving you more suction.
An Impeller fan for the G3 Kirby will run about 18-39$ for the fan. More for labour.
Good luck,
Mark
Nov 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
I need a manuel to replace a broken fan on my g4 kriby
We have actually recorded a very informative do it your self video on how to replace the fan on a Kirby Generation upright.
The video is a two part video, but this explains step by step how to remove the old fan, and put the new one on.
If you need to purchase a new fan assembly, here's a link to the Fan assembly for your Kirby G4. Unfortunately you may only purchase them as a complete assembly:
Genuine Kirby Vacuum Fan. Kirby Part # 119096S
Here's the videos showing how to replace the fan:
Part 1:
Part 2:
Hopefully this helps you with your problem! If this did help, please be so kind and rate the repair, or leave feedback for me. This is very appreciated by the Fixya community when someone is able to answer your question, and assures that experts continue to answer free questions, instead of just the premium paid questions.
Thanks again!
Chris Jones
GoVacuum.com
May 15, 2010 | Kirby G4 Bagged Upright Vacuum
Th end of the shaft that come from the motor is worn out, and won't hold the belt well. How do I change it?
Thanks for the clarification. I have never seen this problem previously in a Kirby. I wonder if the belt keeps sliding off because it's been stretched out? After about 1-2 years, the belts on the Kirby will stretch out to a point where there can possibly slide off the motor shaft. Have you tried just replacing the belt on the unit first?
If you're sure that it's not the belt that may be stretched out, and you'd like to replace the motor shaft, you certainly may do this. The only problem with this is the motor shaft is not sold by itself as a separate part. The only way to purchase this motor shaft is to purchase the entire fan assembly, which includes a new fan, and the hardware necessary on the fan assembly.
Here's a parts diagram that shows you the motor shaft is sold only in a completely assembly:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/kirby-generation-parts-diagram.pdf
If you haven't already purchased the motor shaft, here's a direct link to the motor shaft and fan assembly on our website:
Kirby Generation Fan Assembly With Motor Shaft and Hardware
In terms of installing it, we've actually recorded a video repair on how to replace the fan assembly, which involves removing the motor shaft in order to get the fan off. Since you have to purchase the fan assembly anyways in order get the motor shaft, you may want to go ahead and replace your fan assembly at this time also. Even though your fan may not be broken, on Kirby's the fans can become coated with dirt and fine dust, which can sometimes lead to the Kirby exhausting a bad smell. If you'd rather not replace the fan, you may remove the motor shaft without disassembling the entire machine, you'll just need to secure the fan somehow so that the fan doesn't spin while you're using a nail to turn the motor shaft off.
Anyways, here's the video repair that we recorded. I hope that this helps you. If you found this helpful, please kindly rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair. This is really what keeps Fixya repair professionals continue to give free repairs online.
Here's Part 1 of the video:
Here's Part 2 on Replacing the motor shaft and fan:
If you have any follow up questions, I'd be more then happy to answer them for you, please just add another comment here on the repair page, and I'll be more then happy to answer any follow up questions that you have. Thanks again for rating the repair, I greatly appreciate this.
Chris Jones
GoVacuum.com
Apr 15, 2010 | Kirby G5 Bagged Upright Vacuum
Replace my fan on my kerby
I had to replace mine fan yesterday. I broke away some of the outer pieces and grabbed the fan around the center with some vise grips and put another vise grip on the shaft. ( You can also put a hard steel tool of some kind through the hole in the shaft) when facing the front from the attachment side the shaft unscrews when turning it clockwise.It comes apart right in front of the fan where the washer is.
Jun 06, 2009 | Kirby Heritage II Vacuum
How do I change the fan on my model 2HD kirby
Generic problem for all Vacuums
How do I change the
posted by Rogor on Apr 18, 2008
How do I change the fan on my model 2HD Kirby
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st you need to remove the head with the revolving brushing by dialing off the belt and undo the Kirby lock @ the top o the bell housing. Remove the head and that will expose the fan and the fan housing. The fan housing is held on by a couple of screws and once you removed the screws then you need to separate the fan housing from the motor section, it is held on by a Kirby fan housing sealer that is clear – so try to separate the fan housing with a knife or screwdriver, once the fan housing is off the Kirby fan is screwed on I believe either clockwise or counter clockwise and un-screw the fan and follow the reverse situation on installing the fan but you need to use the clear Kirby Fan Housing Sealer to re-seal the fan housing and let it dry and wipe of the excess clear sealer before putting it back together again. Always remember on the Kirby vacuums – use genuine Kirby parts on the repairs, it does make a difference. Then go back and place the Kirby head back on the vacuum – lock it on place and then re-dial the belt onto the Kirby fan shaft, plug your vacuum in the wall outlet and test run the vacuum.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874
Apr 18, 2008 | Vacuums
Kirby G6 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
