Question about Zebra Z4Mplus Label Printer
Zebra Z4MPlus doesnt communicate with PC
My Z4MPlus Zebra printer has driver installed on PC and RS232 cable plugged in but test print doesnt even get LEDs on printer flasing, Label size is also 100% correct, is there any other plan what to check PLS?
  • cebotha Mar 13, 2008
    Thank you for this great insight into my problem, I think you are right about the parralle cable, only problrm is my laptop that I do the develioment on doesnt have a parralel port, but I will make a plan to use a port repeater or normal pc for this
    Thank you very much
  • Anonymous Mar 30, 2014
    The zebra Z4Mplus barcode is too big
  • 3 Answers
Ok,
This machine has a parallel port. Try to print via parallel cable. If it works, consider staying with it. Serial ports are a pain to manage.
If you absolutely have to do it via rs232 though....
Question 1. Has it ever printed?
If yes, Go into Windows Printers and Faxes control and select the Zebra or whatever printer that you are using. Right click on it and you should get a menu that at the bottom say "Properties", select that, then you should get a new window with tabs at the top. You want the tab for "Ports". Select it and you will see all of the different output ports that you can direct your printing. RS232 is a COM port. So start at COM1, check it and try to print. If that doesn't work, go to COM2, etc.
Last resort, If you can't get control via the printer driver program, you will have to try redirecting the print manually (now you will understand why I said to stay with parallel output).
What you have to do is redirect your printing via the dos "mode" command.
Under "Start Menu" goto "Run" and put in "CMD" and click "OK".
This opens a black square window with a cursor blinking. Type in this:
mode com1:9600,n,8,1 (enter)
mode lpt2=com1 (enter)
Tell your program to use LPT2 if you can and see if it works.
By now a parallel cable instead of RS232 should be looking really good.
Posted on Mar 13, 2008
My zebra z4mplus just start printing at the center of the label instead of at the left side of the label. Instead of a normal full printing on a label, now the left half of the label is blank, and the...
Welcome to FixYa.
The Zerba Driver might have been corrupted.
Uninstall the Zebra Driver/Software from the Control Panel.Re-install the Zebra driver using the Disc that came along with the printer.
Thank you for using FixYa.Have a great day.
Nov 29, 2011 | Zebra Z4Mplus Label Printer
Hi i bought a Z4mplus.. I have a laptop that only has usb ports and have connected the zebra with a usb - serial converter... however the computer installs the printer driver but wont send any information...
Make sure the serial port parameters match between the printer and the usb-serial driver. The Zebra printer is usually set to 9600 baud, 7 data bits, Even parity and 1 stop bit. The serial driver is probably different. The mismatch will prevent communications.
Hope that helps !
May 06, 2010 | Zebra Z4Mplus Label Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
I'm inputing ASCII via RS232 would like barcode printout
You will need to send the data using ZPL or the printer won't recognize it , if you don't have experience in this area print through the Zebra Print Driver should work. In your application use Barcode 128 as the font and see how it goes
Jul 24, 2009 | Zebra Z4M Printer
Zebra 105SE 25 pin serial cable
error can be on the pc.side or the printer's:
check
- if in windows the LPT ports are addressed properly (if u got a many usb ports, then windows adresses these first and skips the older lpt's- same applies when using an external usb-hub/splitter!)
- that there are no dma or irq conflicts
(see device manager)
- if the right driver is installed, if it suits the windows version u are using/has been written for it
- doublecheck printer against another printer
on your pc using same port
- and/or try to connect it to another pc
so u make sure on which side the error ocurs!
least: check the cable itself
Jun 13, 2009 | Zebra 105Se Thermal Printer
Zebra 4MPlus printer erroring
check the driver setting USE PRINTER CONFIGURATION
Mar 17, 2009 | Zebra Z4Mplus Label Printer
Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Mar 09, 2009 | Zebra Z4MPlus Printer
Printer is taking a long time to print. Before it
Try changing communication cable and verify that the driver has correctly set the port used (LPT, COM, etc).
Roberto Martinez
Mar 03, 2009 | Zebra Z4Mplus Label Printer
Zebra z4mplus
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
May 21, 2008 | Zebra Z4Mplus Label Printer
NO COMMUNICATION
hi i have zebra z4m plus printer when i give them command for printing it's not printing and i need a solution can you please help me thankyou
Apr 10, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
1,196 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
