Question about Danby DKC646BLS Full Size / Pony Beer Keg Cooler
Danby Keg coupler
I took the coupler apart to clean it and Iam not sure about the ball inside where it gos, or the little black plastic spacer not washer.I need a pictures can;t find a website.
    Top Expert:
  • Danby Master
  • 43,901 Answers
Check YouTube for something similar.
Posted on Oct 11, 2017
3 Suggested Answers
SOURCE: Danby Keg Cooler foam problem
Set co psi 8to10 lbs
Posted on Aug 03, 2007
  • 99 Answers
SOURCE: Installing the lines to the keg
check to see weather or not a pump is needed to pressurize your keg.
Posted on Jan 26, 2008
Where do the check balls get placed in the valve body of transmission?
look on spacer plate if you look close you will see where thy go
Apr 16, 2015 | 1996 Dodge Neon
I have a danby kegerator and i just tap the keg and all its doing is spitting air with some foam and i tasted the beer it was completly flat i need help asap!!!
try changing kegs sounds like the tube in the keg is broken the keg has a tube that runs to the bottom of the keg inside and u push air into the keg to push beer thru that tube and into a cool glass and down to ur gulletbut it sounds like u have a defective keg or an empty keg
Feb 24, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Inside fan on Keg Cooler needs to be replaced
Call them and ask to buy the part it should be pretty cheap. I just bought a replacement keypad for mine and they sold it to me right on the phone no hassles
Jul 23, 2009 | Danby DKC645BLS Compact Beverage Cooler
Flow from faucet is impeded
This happens a lot when you clean the unit and you but the little tiny ball back into the tap incorrectly. Check your ball for proper placement within the tap.
Jun 13, 2009 | Danby DKC646BLS Full Size / Pony Beer Keg...
Foamy beer
Keg's are normally pressurized at 13 psi. If you only set yours at 8 psi then you are going to cause problems. You should always start at least the same psi that the keg is set to. If you can talk to the keg company as they all differ some. Common problem is to lower the psi which will cause foam until you reach about 1/2 full or a little less then you should get less foam but your beer will become very flat. Too much pressure is usually better than too little, even with too much pressure you'll see the beer come out fine but will start to foam when hitting the glass/pitcher. Also note that the coupler's that Danby use are very cheap, check the CO2 vale (between CO2 line and coupler) to see if there are any cracks or anything.
Sep 27, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Too much foam
well you are right the CO2 is causing the foam you may need to replace the regulator on the tank it is most likely bypassing the bellows inside...as a temp fix you can shut down the co2 and bleed off the air then just crack open the tank to (hand) regulate the flow ..
Feb 16, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Jan 26, 2008 | Danby DKC645BLS Compact Beverage Cooler
New danby kegerator - tastes like rubber hose
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Dec 30, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
If you are getting foam then finally poors fine you have a temperature problem. If you are getting constant foam then you are probably looking at a pressure problem. First of all make sure that you let your keg sit for at least 4 hours and get down to 38 degrees before you tap the keg. Also ensure that your pressure is set to at least what the pressure is in the keg (generally 13 psi). If you can, try to ask the beer manufactures (if you use a microbrewery) what pressure to set it at. One brew master told me to start at 15 psi and adjust from there.
If you still get foam and you can guarantee that the temperature is correct then you are getting some agitation from something else. Double check all your washers and even check your stop valve on the CO2 line to the coupler. Sometimes the lines are not the correct length or even the correct diameter, when the beer is forced through the line if it starts out thin and then expands or vice versa that gives beer a chance to get agitated and cause foam.
Finally the equipment that is used on these systems are generally not that great. I had a Danby Chill'n Tap and replaced the coupler and the tap and all the lines and that solved my issues, even though my problem was probably a cracked valve for the < $80 it cost me to replace everything it wasn't worth my time to figure out exactly what was wrong with it.
Jul 26, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby DKC646BLS Full Size / Pony Beer Keg Cooler Logo
187 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
