Question about Kyocera FS-2000D Laser Printer
Call service after turning on power, showing call service 0150:0094443, please help me to sort out.
  • 51 Answers
This is a mainboard problem. You will have to try and do a firmware upgrade first, if this do not work your mainboard is damaged. The firmware can be downloaded from kyocera's website where you will have to unzip and copy it to a flash drive/memory card. Switch machine off and insert card. Switch machine back on and wait for firmware to be downloaded. Switch machine off and remove card, switch back on.
Posted on Mar 26, 2008
6ya staff
SOURCE:
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
Play station is hooked up on turned on (blue light) tv is on and on the right input but nothing shows up on the screen. Please help
Please try these easy steps to sort your problem out :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Aug 23, 2010 | Sony Playstation 3 (PS3) Console
When switched on there is no power at the printer. lights do not come on. I have checked the power supply cable and the 5amp fuse, still no response.
www.scribd.com/doc/.../Canon-iP4200-Service-Manual
Please find above, a service manual, for a similar model, however this has the same troubleshooting steps to perform to sort out your problem. If there is NO LED's NO sign of life at all at power On, then probably your PSU, has gone faulty, or you have a fault, bad enough to shut down the PSU. The troubleshooting steps should help you sort your issue.
Jun 20, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Tv turning on and off.
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Jan 31, 2010 | Televison & Video
It wont turn on...........
Jan 22, 2010 | Akai LCT2060 Television
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
Dec 08, 2009 | Microsoft Xbox 360 Console
VA712 Lcd monitor taking long to show display
My VA712 is exactly the same as yours. Did you ever get a solution?
Thanks,
John
Oct 04, 2009 | ViewSonic VA712 17" LCD Monitor
Tv does not turn on
You does not mean about picture clarity before this problem occurs. Former the picture clarity is well and good means picture is not problem. There is a problem in horizontal deflection area.May be flyback transformer failure shows these type of problem. This service should be done by technical persons only.
Aug 27, 2007 | Sony KV-32S42 32" TV
Have a small lcd flat screen tv- 4 mos old
you have to repair its power supply, there are a couple of capacitors you have are almost short that's why the TV is turning of so to be in safe mode from power failure. Please contact a good technician in you place for a service. Patrick
May 21, 2007 | Symphonic ST419E TV
Kyocera FS-2000D Laser Printer Logo
235 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Adorjani Laszlo
gggg
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
